Re: 2003 sv650 parts & advice :-)
does the radiator leak? I raced mine for parts of 3 years with it practically bent around the frame, it finally gave out rubbing on the fairing. I researched sv rider and Delkovic was supposed to come out with a gen 2 aftermarket radiator for around $150, but alas I needed one quick and paid top dollar for a used one on ebay.If you need calipers or the whole brake system I have it cheap. I bought the bike salvage with 40 miles on it and changed out a lot of stock parts that are perfect, let me know if you need anything
I have call forwarding on if you want to call today, or we can talk Monday
Quote:
Originally Posted by
OreoGaborio
I'd rank Elka below Penske... though I don't have much of any personal experience with either. All my bikes came pre-equipped with Ohlins shocks, courtesy of a previous owner.
Depends on the shock.
I have an Ohlins double on my SV and a Penske triple on my 1000RR. I like the additional compression adjustments on the triple.
Both shocks are super-high quality.
SVRACER01
Just spotted a Penske on the STT forums. He had forks too.
i want!
EDIT: its for a 2nd gen 650, crap. plus its setup for 160, too light for my ass.
SVRACER01
Swapping springs for rider wt isnt expensive.
wouldnt i have to have it revalved as well, along with the stiffer spring?
darkduc7
And make it longer, Too much in parts, around $560 parts and labor for a revalve, spring, shaft and body.
gmdboston
But that's to make it work for the other gen SV, right? You wouldn't have to do all that if you're just changing for rider weight, correct?
Not to get off topic but I looked for months for a used penske for my gen1. I found that they either weren't sprung for my weight or needed a rebuild. Adding to that....they were not bargains to begin with.
In the end I decided that used was not the way to go.... I saved enough money on other used pieces(plastics, master, clipons,etc) that spending for a new shock was worth it.
I called GMD and had my Penske days later. To me it was worth it. Just my .02.
Charlie
Charlief
Charlie
AWbsolutely. I did all the suspension upgrades on my DL650 [street].
When I bought my SV650S I made an appointment with GMD before I'd even picked up the bike. So first time I hit the track, the suspension was perfect, and the cost was very reasonable: less than what I paid on my own for the DL.
OreoGaborio
Right, 03+ SV's have a shorter shock than the 99-02, and the valving in a Penske is flexible enough to cover the range of spring rates for most riders, 83 lb Supermodels, and Sumo wrestlers not with standing.
gmdboston
so, if a penske has a 425lb spring on it, you could go to a 700lb without revalving? nice
darkduc7
No if it has a #425, you could use springs from #375 to #475. For a #700 you would need different valving.
Good choice on buying new....A gen1 Penske 2 way with remote was listed on SV rider for $315. It needed a rebuild but lasted less than an hour then it was snapped up.....hell I almost bought it as a spare.
I know you needed a gen2 but as we see...when they are listed ...they sell quickly.
Alvecchio
I think I'm gonna end up just buying a new one at the time my bike goes to gmd. Which by the looks of it will be around feb or so. That'll give me some time to save up a cushion to get what I want done(and done right).
Still looking for stuff like rearsets and clipons. Preferably woodcraft stuff. Used race plastics also.
I have a new set of Woodcraft 41mm clip ons for $125
Alvecchio
What's this I keep seeing about an r6 throttle tube. Worthwhile upgrade?
i've got one if you're interested. it was i think $31 or $41 (forget what the dealer charged). i never needed it, as i found out that i already had one on my bike. if you're interested in it, let me know.
