Wirelessly posted (Samsung Lube.... Er, Glyde: BlackBerry8520/4.6.1.314 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
They're like 10 bucks.
Printable View
You got raped. I got my R6 tube from Noel for like 7 bucks.
06 R6, $16.23 on RonAyers http://www.ronayers.com/Fiche/TypeID..._HANDLE_CABLE_
then it must've been $31 that I paid at Brockton Cycles.
only issue with the R6 tube is that you'll have to use a dremmel and shave off a small area for the throttle cable. The R1 tubes fit right on without any modification needed.
Yeah, it's a direct swap for 1st gen. If you have a 2nd gen it'll fit, but you can't go full throttle. Some trimming required.
http://canyonchasers.net/shop/sv/R6-throttle.php
I'm not sure what year R6 tube I got from Noel (think it was an 03-05) but the one that I got from Joel Allen at the track had a slightly larger cam, shortening the throw a little more. Probably a later model tube since he's got an 06. Both required some dremeling.
Yamaha Part # 5SL-26240-01-00, this is from a 05-06 R1
I think I paid like $12
this was the R1 tube.
I'm not sure about the R6
I think I'll worry about this tube later. :-)
Hahaha...r6....$6.
Jim I got some swamp land I can sell ya!
Fwiw...I knew about it for years and when I finally did it I wondered why I waited so long. Easier and faster to get the wfo out of 2 and 4 without doing the finger walk around the grip.
You know what will really make it go faster? An R1 motor.
