KTM XC-W (Lighting, PDS) = Husky TE (Lighting, Linkage)
KTM XC (No lighting, Linkage) = Husky TX (No lighting, Linkage)
Printable View
Also - Significant tuning differences between XC-W and XC, and TE/TX.
XC-W and TE are more mild.
XC and TX are more wild.
Interesting... I was under the impression that the XC/XC-W had the same timing/mapping while the SX got a different head/cylinder/cdi to wake it up? In my use case none of that actually matters, as it's just the clutch and transmission that'll be retained anyways. :P
I think the 250 changes between the models but the 300 doesn't.
The part numbers for the ECU's and the cylinder heads are different between XC's and XC-W's (given same model year).
The XC also has a "semi-close ratio" gearbox, with taller 1st and 2nd gears, while the XC-W has a wide ratio box.
Plated ‘11 250 converted to a 300 in eastern CT
Error | Adventure Rider
Sadly, XCW, and PDS suspension, so not viable for my project, but would likely make a good bike for someone. Thank you for the heads up!
Looks like it was originally a 250 XC. Awesome price!!
Fine here you go. For sale - 2012 KTM 300 XC - Massachusetts | Adventure Rider
