Results 1 to 25 of 28
Good mechanic to track down an SV650 electrical problem near Waltham, MA?
    Member Rusty the Scoob's Avatar
    Concord, MA
    Got an electrical problem with my SV650 - riding to work this morning I made it about a mile from my house and it started cutting out - lights, gauges, ignition, everything, just as if someone was turning the key off and on.
    Anyone know a good mechanic somehwere near Waltham, MA? I hate trusting anybody with my vehicles but I really don't feel like chasing this one down by myself in my driveway.
    2002 SV650N - Daily Commuter
    www.fennario.us - my Grateful Dead tribute band
    Senior Member tonyd's Avatar
    Jul 2004
    NH
    Re: Good mechanic to track down an SV650 electrical problem near Waltham, MA?
    sounds like just a loose wire somewhere or maybe your reg/rectifier going.
    2008 Kawasaki Versys 650
    1972 Honda CL70
    Quote Originally Posted by Rusty the Scoob View Post
    I would look it over first cause what you are describing could be just a loose wire on the Battery...so for 75$ thats Rape Rape......look it over save some $$$'s
    Concord, MA
    Yeah, you guys are probably right... I'm just not in the mood to work on it after spending $120 to have it towed like 3 miles. But I'm in no mood to load it onto my trailer, either.
    Also - Every day that I don't ride it to work it costs me at least $12 in parking and $6.50 or so in gas... so if I don't figure it out fast, I might as well have taken it in...
    Take the seat off and make sure the battery cables are tight.
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Lifer DuncanMoto's Avatar
    Quote Originally Posted by BLACK SQUIRREL View Post
    and clean. Ask me to show you at the shop when you come by today.
    Feb 2010
    Southbridge
    Drop it at Landrics Boston Moto if it's not the loose cables. I have an extensive background in electronics. I'm sure I can figure it out for you. And there is a Nesr discount on the labor. Pm me or call 774-200-6395
    Degsy: "i never had red hair"
    Concord, MA
    Thanks, guys!
    I made an attempt at tightening the battery cables before even calling AAA but all I had were the tools from under my seat.... it'll definitely worth taking another shot at it with real tools. I'd love to hear any and all thoughts you have on the matter, Ted! See you in a couple of hours.
    Plan B will be to tow it down to Landric. You're reachable over the weekend?
    Lifer Danz19899's Avatar
    Grafton, Ma
    not sure how u plan on getting it there but dont have it towed lol. I'm sure rich will charge u a lot less to pick it up that those damn towing companies.
    Bergs what was wrong with laurens bike at the track that time it shut off in the bowl. i remeber u fixed it dont remember what u fixed tho
    www.bostonmoto.com
    Ride to live, live to ride
    Feb 2010
    Southbridge
    I'm reachable this weekend. Yes. And we can pick it up for you if need be. Location??
    Quote Originally Posted by Danz19899 View Post
    The issue with the regulator/ rectifier? Fried connections.
    . dipthat's Avatar
    Boston, MA
    Call Rich 774-200-6395, affordable, great service. You'll be very happy. I'm saying this from past experience.
    2004 Yahama RX-Z
    2004 Yamaha 125-Z
    2008 Honda CBR 600RR, bitch is SOLD
    Castrol R30
    Can't go wrong with Landric's ......
    Grafton, Ma
    thanks bergs sounds like a similar problem on this sv.
    www.bostonmoto.com
    Concord, MA
    Quote Originally Posted by landricscustoms View Post
    I'm in Waltham... I can trailer it but it's not easy, especially if it doesn't run. BTDT.
    Fried connections on the R/R, eh? R/Rs seem to be a common problem on these SVs, so I upgraded mine to one from (IIRC) a CBR600. I'll definitely be pulling the plastics tomorrow to have a look at it.
    Check your grounds, check your connectors on the harness and check any terminals on the battery. You'd be surprised how easy it is to spot a loose connection.
    If it has a wire going into it, make sure it is tight. It is also a good idea to unplug then plug back in every connector you can spot under the seat and up the wiring harness. SV is pretty easy to work on due to the hinged tank.
    2016 BMW S1000XR
    Super-Dooper User ɹǝʍoןandɹǝʍoן's Avatar
    Salem NH
    def check your battery terminals and your battery frame ground for corrosion.
    Feb 2010
    Southbridge
    give me a call if you need my help
    Arlington MA 02474
    "Roadside assistance" is $39 a year for all your vehicles with AMA membership.
    Grounds, check all your grounds (like they all said).
    Concord, MA
    That is a good tip about the AMA! I need to go look into that as soon as I'm done wrenching.
    The electrical problem seems to have been just a loose battery cable, not even visibly dirty. I tightened both connections again with real tools instead of under-seat tools and it fired right up. I hope it's ok to Lock-Tite them, because I did. $120 and a wasted morning, ugh.
    Quick question about my new chain - do I leave that thick white paste-like grease on it or clean it off? It feels like it's going to collect every loose piece of dirt and dust within 5 miles.
    Concord, MA
    Ignore that premature success post. I made it to the end of my street and back, and now it's dead again.
    Looks like the ignition - if I turn the key past the steering lock to the parking-light setting, the light goes on - but when turning the key to the actual ON position the bike stays off.
    So it's off to Landric tomorrow, and hopefully back asap. I hate riding the train to work and it's damn expensive.
    Feb 2010
    Southbridge
    your in great hands Dan, i'll pick her up tmrw afternoon and get her back to you asap
    Concord, MA
    I feel really good about this! I'm glad it's finally getting some real help!
    Can you also double-check my rear-wheel alignment, please? I want to know if I'm doing a good enough job for commuting. (I left the cotter-pin off on purpose.... I'd have put one in if it were ridable)
    Not a cool kid Charlief's Avatar
    Ipswich
    So what was the diagnosis?
    Just curious as I also have a SV.
    Me no likey crash
    We repaired it a couple of weeks ago at Boston Moto. Took a while to diagnose and a few days to get terminal pins in the oem type but she's good to go. I'll let dan chime in with the fix details.
  1. Wierdest electrical problem ever
    By smokinjoe in forum Bike Maintenance
    Last Post: 07-23-17, 06:00 AM
  2. Electrical Problem?
    By Omahastylin16 in forum Bike Maintenance
    Last Post: 04-22-10, 03:29 PM
  3. Daunting Electrical Problem on F4I, HELP
    By MrBreese in forum Bike Maintenance
    Last Post: 09-06-08, 07:07 AM
