Looks like Dan is AWOL. Not sure if he patrols the forums much.
The problem was a bad (loose) ground wire to the regulator/rectifier. It shares it's ground wire with the starter relay. The starter relay connector pins were all burned out and the ground wire was blackened up to 2 inches back from the connector. We changed the pins out on the plug and replaced the starter relay.
