Block is good, heads are good.
Port head gasket let go and water mixed with the oil. There were women and children onboard at the time so I ran it til it popped. I believe a con rod snapped. The engine was at low RPM (1500-1800 ish) when it took its final breath. Poked a hole in the steel oil pan but no other damage to the block.
I can deliver for a fee or you are more than welcome to pick up from my house. I will help load if need be.
Engine is clean, all hardware is in great condition. It is my belief the builder did not torque the heads properly.
Excellent candidate for a long block rebuild or sell the heads and pocket $500.
