I'm in the process of bringing my beloved old Sprint RS back to life as a street fighter after sitting dormant for almost two years. I just got it running and it is running surprisingly well, took it around the block and it did great considering how long it's been sitting. The rear caliper was seized and pretty corroded. I was going to try to rebuild it, but found a very reasonably priced complete rear brake system on ebay and bought that instead. Will probably put a new chain and sprockets on soon, change the oil and flush the coolant, as well as give it a thorough cleaning.
My question: The bike's fork seals are weeping quite a bit and obviously need to be changed. I have effectively zero suspension knowledge and after doing a little research decided this wasn't something I wanted to try myself, especially since I don't have a garage or any of the specialized tools. So how much is this going to cost me and can anybody recommend a shop? They are right side up forks, if that makes a difference. I don't want to do any kind of upgrade to the forks as I plan to swap in some Busa forks eventually if I keep the bike, so only wondering how much it'll be to change the oil and seals. Thanks!
