Results 1 to 25 of 34
Rim locks and wheel balancing
    TWINS! xrocket21's Avatar
    Central Maine
    On my KTM I swapped out the dual sport tires for some Metzger dot legal dirt tires and added rim locks. Lots of vibration over 50 now. Can you balance dirt tires?
    I93/495
    Re: Rim locks and wheel balancing
    Yes. Balance like normal or throw dynabeads in the tubes. They even have weights you can crimp onto spokes.
    2012 Tiger 800 XC
    Arlington MA 02474
    ... or go old skool
    Central Maine
    Im thinkin harbor freight balancer and spoke weights... thanks guys.
    Central Maine
    Got myself a tire balancer and a stand for $75. Weights come Friday or Monday
    Been using the HF balancer for years. It is fine
    Stick on weights for street bikes. Crimp on spoke weights for the dual-sports.
    Although in truth I skip the balance all the time without issue.
    Central Maine
    I dont street ride it a lot, but the little test ride I did, it was not great past 40, and pretty bad over 60. Soke weights from ebay should be here saturday or monday.
    Not sure how the KTM wheels come on newer bikes, but my 2011 had the option for two rim locks. One lock was installed, the other on the opposite rotation was just a rubber plug. I added the second rim lock on my bike and it solved most of the vibrations. You’ll never get rid of all of it with knobbies, simply because of the spacing between the knobs
    Central Maine
    These just had one hole for the rim lock. Right near the valve stem too, I was surprised it wasn't opposite,
    I would go over the balancer a bit when you get it. The bearings they use are less than optimal. I've taken them apart and greased them as they stopped spinning freely at one point. Also the concentricity between the bearings isn't great which causes the axle to want to walk and increases friction in the assembly.
    I'm sitting here wondering if dyna beads would work with dual sport/off road tires if they are setup tubeless...
    Edit...prolly not with the rim locks.
    Dublin, NH
    I don't think concentricity of the bearings really matters if all you're doing is static balancing and the bearings move freely. The stand my buddy and I have you can't even adjust the bearings to be concentric, that is just implied in the assembly of the frame.
    2023 KTM 890 Adventure R
    Central Maine
    I was tempted by dyna beads as I could put them in without taking the wheels back off the bike, but research found mixed reviews.
    Yeah, I think close enough/better than it is will be good enough for me for what this will be used for.
    I even got the Rim Locks in first try with no issues
    I93/495
    Been using dynabeads for 50k or so at this point. I'm happy with them.
    2012 Tiger 800 XC
    Either way the bearings not moving is an issue.
    I've installed dyna beads for people with no issues.
    Central Maine
    Probably should have asked here first.. oh well
    I have some killer light bearing oil from my RC cars that I'll put on em.
    Thanks guys.
    I'm trying to get everything in line for this j day race in July!
    Put real acerbis wrap around hand guards on last night. Ordered knee pads today.
    Thanks guys.
    awesome !!
    Oct 2020
    Chelmsford, MA
    Toss me $200 for the dynamic balancer tool and I'll give you 20 free dynamic balances
    https://smile.amazon.com/gp/product/B073DKJ7RV
    Central Maine
    I live up in a rural part of Maine
    Oct 2020
    Chelmsford, MA
    ah can't get dere from nyeah, I'm from away
    https://www.youtube.com/watch?v=Ecg_WizWicQ
    Central Maine
    Went pretty fast. Rear took a ton of weight though
    wow, that is a lot of weight ... alternatively, could always drill the opposite side and install a matching rim lock ... but the work is done now
    EDIT: i assume OEM rim lock, another option to potentially lighten things up is to switch out for a MP LiteLoc superlite
    Dang that's a lot. Did you get brass weights?
    Central Maine
    It is the oem lock that came with the bike.
    Yeah, they are brass weights. I also thought it was a LOT more weight than I expected for it to balance. The rear seems like a lot more than the little plastic rim lock itself would weigh.
    I took it for a spin and it rides smooth as hell now though!
    Arlington MA 02474
    Them's some deluxe weights.
    Naturally corrosion resistant though.
    I wonder if you got unlucky and the heaviest part of the tire is at the rim lock.
  1. Locks
    By aprilb in forum General Bike Related
    Last Post: 07-08-14, 12:34 PM
  2. Chain locks
    By Pittenger5 in forum General Bike Related
    Last Post: 02-15-10, 06:32 PM
  3. Tire balancing...
    By Tricky Mike in forum Bike Maintenance
    Last Post: 06-12-06, 01:03 PM
