Results 1 to 9 of 9
Ignition Wiring ??
    Pepperell, MA
    Ignition Wiring ??
    I am trying to finish my R1 so I can ride it, and only have a few minor things left.
    Any suggestions for what to cover wires to strenghen and protect them. This bike was stolen and has the wires exposed at the moment. I dont want to replace the whole harness If I do not have to. Once I get something strong with some sort of mesh cover I will shrink tube over that to make it look stock, and neat...
    Where to get supplies, and what exactly am I looking for???
    www.tailofthedragon.com
    Ignition Wiring ??
    i'm sure you could probably hit up any hardware store... get some sorta wiring harness wrap... i think i saw some once... kinda like electrical tape, but thicker. just wrapped it around the wires like the grip of a baseball bat or tennis racket
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    Re: Ignition Wiring ??
    Honestly, you can probably just get some of the nice shrink tube and shrink tube right over the damaged bits... Its what I would do anyhow...
    Cheers,
    Chris
    But when we ride very fast motorcycles, we ride with immaculate sanity. We might abuse a substance here and there, but only when it's right. The final measure of any rider's skill is the inverse ratio of his preferred Traveling Speed to the number of bad scars on his body. It is that simple: If you ride fast and crash, you are a bad rider. If you go slow and crash, you are a bad rider. And if you are a bad rider, you should not ride motorcycles.
    Ignition Wiring ??
    only problem w/ shrink tube is that there's usually a big fat wiring harness at the only end you can slide it over.... and 9 times outta 10 murpheys law kicks in & the only sized shrink tube over the wiring harness won't shrink tight to the wires... always happens to me
    Pepperell, MA
    Ignition Wiring ??
    I am going to try a electrical supplier tonight and see what I come up with.
    Thanks!
    Ignition Wiring ??
    You can use that black, plastic, conduit-type stuff. I've used it alot on the big truck with all the extra electrics I have on it. Just slice it along the length, slip it on and wrap a little electrical tape to hold it together. Holds up surprisingly well...
    I've never been a big fan of the shrink tube stuff. Don't know why really, just not...
    I've also used 'liquid electrical tape' on my trailer's wiring. Works pretty good, neat stuff...
    Ignition Wiring ??
    McMaster Carr has braided Polyethylene Mesh Sleeving and Woven Nylon (basically Nomex). It resembles the old chinese finger traps. Solder the wires together, put a small piece of heat shrink over the patch overlapping the jacket of the wire. Then bundle the entire wire harness into the sleeving. If you really want to seal the deal cover the entire thing in heat shrink. Good Luck...
    Pepperell, MA
    Ignition Wiring ??
    Originally posted by SSearchVT
    McMaster Carr has braided Polyethylene Mesh Sleeving and Woven Nylon (basically Nomex). Good Luck...
    Thanks ! I'll check my catalog at work tomorrow.
    I already have sauder wire a saudering pen heat shring tubes so I am ready to rock and get the wrapping done, just wish I could just go pick this wrap stuff up locally like tomorrow.... I checked C.A.P and NAPA with only crappy plastic sheathing...
    Everything else on the bike is done!!! I might bring it to work tomorrow?? Not sure I want to risk using my RC plate just to ride it.... I am dying to ride it though... It runs and sounds mint! All my lighting issues are resolved, my battery replaced and working nice! Woooohoooo I can wait to get this inspected for a reconstruction title and put her on the street!!!
    Jul 2002
    Everett, MA
    Ignition Wiring ??
    Eh, put the RC plate on her and ride that bitch!
    Just don't go ridin by no cops on one wheel!
    Cheers,
    Chris
  1. Went to Keyless Ignition
    By turbo in forum General Bike Related
    Last Post: 04-01-13, 03:32 PM
  2. Key stuck in ignition!!!
    By njsrikar in forum Bike Maintenance
    Last Post: 01-21-12, 09:16 PM
  3. V-45 ignition module?
    By gregp in forum Bike Maintenance
    Last Post: 05-10-10, 01:36 PM
  4. any one have a ignition box
    By lrrs428 in forum General Bike Related
    Last Post: 06-10-09, 04:28 PM
  5. Ignition?
    By Murphy_101 in forum General Bike Related
    Last Post: 05-22-07, 07:18 PM
