Results 1 to 9 of 9
calling all mechanical geniuses
    Mar 2004
    woonsocket ri
    or at least someone with a shop manual.
    I started to put a new clutch in my 97 maurader. I bought a manual for the intruder 800 because I was told the motor was the same and could use the spec's from the book. (it's also $35 cheaper than the maurader book and available.)
    Well it's not even close, so I need to know the torque specs for the clutch bolts. The intruder only has 4 bolts, but my maurader has 8.
    So anybody in the know,know?
    anybody want a shop manual for the 800 intruder?
    are you talking about the bolts with the springs that hold all the clutch plates together?
    if they are...then i say you tighten them all the way down until they bottom out and i would guess something like 10ft/lbs or something. they are just 8/10mm bolts right?
    Just Registered
    Is it not obvious?
    I'm with the SV guy...
    I know nothing of the bike or situation, but 8/10 lb/ft would be my guess. Put some bloo loctite (#242 if available, oil resistant) just to be safe.
    My 2 vices, not necessarily in order:
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Mar 2004
    woonsocket ri
    the answer to your question is yes they are those bolts. according to the manual for the intruder it is 8-9.5 ft-lbs. but 4 of the bolts in my maurader go into the clutch basket and the other 4 go into a kinda 4 pointed (think chinese throwing star) semi-slip washer type thingy ( I like to use techincal terms ) on the intruder there are only four and they go into the clutch basket.
    In the front of the manual there should be a generic listing for the torque of bolts based on the size. 8-10 lb/ft sounds about right. The most important thing is to make sure they are all torqued to the same value so you get even pressure across the plates. Good Luck...
    Littering and........
    Jul 2004
    Vermont
    Break it off, then loosen 1/4 turn.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    thats what i do lol
    Mar 2004
    woonsocket ri
    thats what I tell everyone who asks
    The correct answer is 7ft-lbs.
    like anybody else cares.
  1. Need mechanical help G12 Loudon
    By smokinjoe in forum Bike Maintenance
    Last Post: 10-09-17, 10:17 AM
  2. I need mechanical skills
    By Petorius in forum General Bike Related
    Last Post: 07-15-15, 01:48 PM
  3. Business | STS Weldind & Mechanical llc
    By racer 1979 in forum Business & Product Reviews
    Last Post: 09-24-09, 12:21 PM
