Results 1 to 25 of 32
Carb help please.
    Just Registered Doc's Avatar
    Carb help please.
    I have a problem with my 03 Xr100r. I got to use it at the race weekend and it was a dog.
    It ran fine at idle but if you gave it more than half throttle it just bogs. So, I pulled the carb and cleaned a ton of gunk out, put it back together and now it runs for a bit and then dies. It won't idle. If I keep giving it throttle it keeps running but if I don't it dies.
    Ideas?
    Oh, and I have a 2 Bros pipe and uni pod. Needle is on the middle clip.
    BOMO Instructor
    EX# X
    Lifer smf's Avatar
    Nov 2006
    Carb help please.
    other than the lack of idle does it run well through the rpm range? ...idle could be a simple mixture screw thing.
    Scott
    Carb help please.
    sounds like an idle circuit. fill the float bowl with carb cleaner. or do a better job at cleaning it
    Carb help please.
    Scott, I think it still has the bogging just a little higher up now (although I haven't tried to ride it, just reved it.
    I'm Gonna try to clean it again
    BOMO Instructor
    EX# X
    Just Registered TLRMan's Avatar
    Northshore/Beverly, MA
    Carb help please.
    Get some really thin wire, and push thru those pilot jets, and air jets...
    Pull a strand off of some 14 - 16 gage wire, to use as a poker outer....
    Too old to rock and roll, too young to die.
    Carb help please.
    Quote Originally Posted by TLRMan View Post
    is that a technical term?
    Carb help please.
    Christ, between you and Pete........
    Mar 2004
    woonsocket ri
    Carb help please.
    ......to use as a poker outer....
    ***WARNING*** don't put it near your eye.
    Carb help please.
    Is it backfiring at all? That's usually the idle circuit. Bogging can be bad gas, air leaks, or a plug on it's way out. Does it run better cold - or when it's warmed up? Check to see if the choke is opening and closing freely.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Carb help please.
    14-16 LOL big. A strand is all you need.
    +1
    www.bostonmoto.com
    Forum Rules
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Carb help please.
    Guitar strings (the small metal ones) work really good for cleaning out jets. I've got some in my toolbox. Always good for a few strange looks.
    With that exhaust, and air filter, did you change your jetting at all?
    They should call Production Twins what it really is, Shitty McBikefest. Rules for Participation: If your bike runs lower laptimes than a lawnmower, you are not eligibile for Shitty McBikefest. -Darrell
    Alex Pearsall #121 ESMRA / #512 LRRS
    Carb help please.
    I searched down all the air leaks, I will check the plug, I did not change the jetting but do you think the stock needle would be adjustable? Maybe someone already did...?
    BOMO Instructor
    EX# X
    May 2002
    Meriden CT
    Red face whatcha use your pick for?
    Quote Originally Posted by rebelpacket View Post
    www.bostonmoto.com
    Forum Rules
    Carb help please.
    Are you sure it's jetting? I *think* this motor still has a points ignition. If the points are worn or burnt, you can jet til the cows come home and it will never run right...
    Carb help please.
    No, his is CDI. Same engine as m '96 XR80. I converted my '88 to a '96 engine and went from points to CDI.
    I have the same/similar problem. Thing runs wicked lean. I raised the needle a bit and it helped somewhat, but it never lasts for long before it sucks ma balls again. Open the throttle wide open and she dies. It does alright if you are slow to open her up, but she is obviously running lean. I'm running stock exhaust and stock intake but no airbox cover. I think getting that cover will be my first try.
    I've opened and cleaned the carb numerous times. Also played with the idle mixture many times.
    Carb help please.
    Running lean sounds right. I'll try raising the needle and reoiling the filter... Maybe even put the stock box back on.
    BOMO Instructor
    EX# X
    Carb help please.
    I tried raising the needle already, not sure if that will do it for you.
    I wonder if there is an XR100 forum somewhere.....go to it Doc! Let me know!
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    Carb help please.
    does it run right if half choked? My 50's are like that til the summer heat gets here... if it works... just keep the choke on.
    Brent LRRS #772
    2006 KTM 560 SMR
    Carb help please.
    Can I hijack this thread, please? Awesome.
    I put the requisite amount of Sta-bil in my 900SS before the winter, and ran it for at least 15 minutes to get the gas circulated through the lines. But it looks like something fucking froze anyway.
    It's been mentioned to me that I should pull the float bowl and clean it out, as that's where the gas/water mix usually gooifies. Can I pull the bowl without pulling the whole carb off? I know my way around EFI, but not carbs...
    Carb help please.
    Nope.
    BOMO Instructor
    EX# X
    Carb help please.
    Thanks Doc. Once I pull them off to get to the bowls, do I have to worry about fucking up the jetting? Do I need to touch that stuff to get to the bowls?
    Carb help please.
    your jets need to come out for a "flossing". That is where the buildup causes problems.
    Carb help please.
    Paul: Okay... but are the difficult to insert/remove? When I hear of jetting bikes (as in tuning them), is it just the selection of jets/needles that is important, or is where they're placed in the carb (think TPS synchronization in EFI world) important too?
    Am I in over my head on this one, or is it really not that hard to do?
    Jul 2003
    Bozeman, MT
    Carb help please.
    Its really not hard to do. Your carb has the same jets in each carb (at least it should be, and if it isn't you've got bigger problems, Your running the Mikuni CV's that came with your SS, right?) To get the carbs off the 900SS, you've gotta pull off the airbox (that includes, battery coils, etc). From there, just pull them off the bike, and drop the covers on the bowls after draining fuel out, and unscrew + clean each jet one at a time. Check the choke plungers too, they seem to have a funny way of getting nasty quick.
    Carb help please.
    AFAIK the jets in each are the same; I had the bike tuned last year at Moto Milano up here in Windham. I thought standard carbs were Dell'ortos? But I could be wrong. What you've described doesn't sound so bad, I might give it a shot over the weekend...
  1. Carb help
    By jaehok in forum Bike Maintenance
    Last Post: 05-22-12, 07:42 PM
  2. Carb syncing anyone?
    By Mr. Gixxer in forum Bike Maintenance
    Last Post: 11-03-11, 06:35 PM
  3. carb sync
    By johnnym in forum Bike Maintenance
    Last Post: 04-20-10, 05:33 PM
  4. kz440 Carb Headache! need CARB GURUS!
    By Bandit12k in forum Bike Maintenance
    Last Post: 05-01-08, 12:44 PM
  5. Carb Day
    By Stoneman in forum Bike Maintenance
    Last Post: 07-14-03, 08:51 PM
