Page 3 of 3 FirstFirst 1 2 3
Results 51 to 72 of 72
Neat mechanical aptitude test
  1. #51
    Portsmouth-ish
    its wrong.
  2. #52
    Just a git... OreoGaborio's Avatar
    Topsfield MA
    its wrong.
    You're wrong... the worm gear is turning towards you... the threads are going right to left. the gear is turning counterclockwise.
  3. #53
    I'm gonna victory R1's Avatar
    Somewhere you dont know...
    Quote Originally Posted by SSearchVT View Post
    The one with the switch that goes parallel to the light - I answered that all three lights would go on. The current would still flow through both legs.
    The path of least resistence.
    No matter how you look at it electricity will travel this way. you could have 10 feet of wire between the bulb and the switch, but wire resistence is negligable. it has no effect to the high amounts of resistence the bulb would have before energizing.
    This is assuming that the resistence stated in the diagram is a light bulb!
  4. #54
    Quote Originally Posted by l3uddha View Post
    so who else didnt pass?
  5. #55
    a little crazy... 978chris's Avatar
    Haverhill, MA
    Quote Originally Posted by R1slowflyer View Post
    The path of least resistance.
    No matter how you look at it electricity will travel this way. you could have 10 feet of wire between the bulb and the switch, but wire resistance is negligible. it has no effect to the high amounts of resistance the bulb would have before energizing.
    This is assuming that the resistance stated in the diagram is a light bulb!
    fixed.
    i was reading it and something kept bugging me but i wasn't sure what it was.
  6. #56
    Quote Originally Posted by 978chris View Post
    fixed.
  7. #57
    recluse Dangerz0ne's Avatar
    North Providence
    damn. 78 and I work on mechanical equipment for a living. that's sad.
  8. #58
    my real name is Jacques Steve's Avatar
    Oct 2007
    Milton, MA
    Quote Originally Posted by hammadown View Post
    I got a 98 on my first try! :banana:
    And the one I got wrong I actually got right, the test makers are wrong!!
    Question: Rapidly compressing air and increasing its pressure does what to the temperature?
    They say it increases temperature. That is wrong!
    Compressing, ie decreasing volume along with increasing pressure.
    According to the ideal gas law: PV=nRT
    Thus increasing pressure while decreasing volume will have no effect on temperature (assumption: pressure increase and volume decrease are proportional, which I would think is a logical assumption).
    Im writing an email. And that is your science geek lesson for the day
    If you got that one wrong and said no effect, add 2 points to your score.
    If you are compressing as in an air compressor, by pumping more air into a holding tank--volume stays the same. But if you were compressing it by applying external pressure to something like a balloon--volume would decrease. Some of the questions are too vague--especially that lever question which one would be easier to lift.
  9. #59
    I made it to question 10 and said fuck this!!!
  10. #60
    The diagram they have is a parallel circuit:
    1/R(resultant) = 1/R(switch leg)+1/R(light leg)
    When the switch is closed the majority of current should flow through the switch leg (assuming small resistance in the wire and switch), but current will still flow through the light leg as well. The light won't be as bright as the others, but it will be lit.
  11. #61
    Hey ladies! ZX-12R's Avatar
    Candia, NH
    Quote Originally Posted by 04ZRX View Post
    I don't care about you're perfect little law, try grabbing the output of a compressor & tell me how quickly you will remove your hand as it sizzles!
    The ideal gas law is not the correct equation for this scenario:
    http://www.nestreetriders.com/forum/425573-post28.html
  12. #62
    Haverhill, MA
    Ok I always get confused between amperage/voltage (strength vs. capacity?) so maybe I'm using the wrong one here, but:
    Doesn't the bulb lighting to any degree depend on amperage? If there isn't enough, it won't light?
    No?
    The drawing doesn't specify, so how do you know there is enough to light the bulb? I think this test question is correct for all intents and purposes, unless they include these other values.
  13. #63
    Registered Architect Crash Dummy Denno's Avatar
    Foxboro, MA
    ok I'll see if i can explain this...
    bulbs are purely resistave loads. the switch is assumed to be a short circuit when closed, but yes in reality there is a small amount of resistance.
    the actual resistance of the bulb is temperature dependant. when current first passes through the cold filament, the resistance is much less than when the filament is hot. The time it takes to heat up can be disregarded for this because it's amost instant to the human eye.
    take any bulb and you can figure the hot-resistance from the power consumed and the voltage across it. A 100 watt, 120 volt lamp has a resistance of 144 ohms when lit, from the basic equations below:
    power=voltage*current
    resistance= voltage/current
    you've got a 144ohm resistor in parallel with a switch. the switch is assumed a short. you can throw in whatever practical switch resistance in there that you want & you wont see light. Yes a very small current will flow through the bulb and you can go back & calculate the power being consumed. Considering halogens are only about 7% efficient, whatever miniscule amount of power you have, roughly 93% of it is turned into heat rather than visible light.
    you can go and make whatever assumptions you want to get the bulb to light, but the values arent given in the test probably to see whether or not people will make practical ones.
  14. #64
    Haverhill, MA
    nerds make shit harder for themselves and never get shit accomplished.
    engineers know the right assumptions to make, and are damn sexy too.
    hmm i guess i'm half and half then.
    i make shit harder for myself, but only in the interest of quality, and i DO get shit accomplished.
    i dislike making assumptions, but I AM damn sexy.
  15. #65
    Foxboro, MA
    lol. i hide my geekiness by drinking dark beers and rocking the goatee
    and dancing before each one of your day time talk shows
  16. #66
    Haverhill, MA
    hahaha, owned.
  17. #67
    http://www.x386.net/TTR/tech/cgi-bin/motorsim.cgi
    Crap, guess I know which side I fall on.
  18. #68
    Quote Originally Posted by Smooth R6 View Post
    Sorry to hear about the dog Buddha, can you kindly stop crying so the rest of the media can move on?
  19. #69
    Portsmouth-ish
    96. only because i confused the battery answers. series = multiply voltage.
  20. #70
    I must be stupid, only 92%. Maybe I should read the questions a little slower.
  21. #71
    FuNkReLISh FireFly's Avatar
    ehhhh
    gotta 70.
    I should of went with my gut. I new the right answer to maybe 60% of the questions I Fudged, I just thought about it too much.
  22. #72
    Topsfield MA
    Quote Originally Posted by FireFly View Post
    WHAT????? YOU???? nooooooo
    Sup bro?
  1. Question for you mechanical types....
    By highsider in forum Off-Topic Stuff
    Last Post: 12-14-05, 11:30 AM
  2. calling all mechanical geniuses
    By dhuze in forum General Bike Related
    Last Post: 06-21-05, 04:38 PM
  3. neat video
    Last Post: 01-16-05, 11:13 AM
  4. Neat link..
    By benVFR in forum Off-Topic Stuff
    Last Post: 10-29-04, 01:48 PM
  5. Kinda Neat...
    Last Post: 05-22-04, 01:53 PM
