Its a race prep sv. I took the fairings and tank off, drained the tank taped off the valves on the bottom of the tank. I sprayed everything (not the bottom of the tank) and then reinstalled. Hooked up both fuel lines and the electrical connector under the tank. Let it crank for about 20 seconds and then remembered it didnt have much fuel in it so I added fuel and then cranked more. It wont fire up.
In an 02 SV will you hear a fuel pump prime or running? Because I dont hear one. Also I pulled the fuel line off the right side of the bike and some fuel was coming out of it as I was cranking it over.
I cleaned the electrical connectors under the tank, I dont know if there was sediment in the tank and when i was cranking with no fuel it might have clogged something? Does it take a while to get fuel back through the system? Is 1.5 gallons enough fuel in it with the tank down to get it started? Any other suggestions?
Thanks guys. My first track day is Tuesday, and the bike is still fairly new to me (havent ridden it yet) but I know it ran.
-Lou
