Results 1 to 15 of 15
07-09 600RR Spark Plugs....
    LRRS/CCS #627 JRide's Avatar
    Sep 2006
    Simsbury CT
    So, after my lowside my bike takes a few more cranks to fire up. I'm pretty sure I fouled a spark plug or two. I went to Manchester Honda thinking they may be a little more expensive but I'm willing to pay a dollar or two more per plug to have them instantly....I'd get charged shipping anyway....yeah......they wanted $26 per plug!!!
    I came home and started searching around and came across this site:
    http://race-mart.storesecured.com/it...HES-detail.htm
    I just paid $51 and change for 4 of them including shipping. Half the price of what Manchester Honda wanted. Not sure what the other bikes run or the 05-06 CBR's but I just wanted to give you guys a heads up.
    07-09:
    NGK-IMR9C-9HES
    DENSO-VUH27D
    John
    04 KTM 125SX
    05 CBR600RR
    07 KTM 250XC-W
    Meriden, Ct
    Re: 07-09 600RR Spark Plugs....
    John, that's retarded money for stinkin spark plugs. I'll see if I can cross reference it to something more affordable.
    Sep 2006
    Simsbury CT
    $10 a plug is still retarded money?
    John
    04 KTM 125SX
    05 CBR600RR
    07 KTM 250XC-W
    FWIW; I don't recall ever paying more than $8 per and that was plugs for a 5 series BMW.
    Sep 2006
    Simsbury CT
    Hmmm....I searched a couple of places but this was the cheapest I found. Noel, let me know what you find.
    John
    04 KTM 125SX
    05 CBR600RR
    07 KTM 250XC-W
    Quote Originally Posted by Butcher Bergs View Post
    It really depends on the bike and the type of plugs it requires. For some reason Honda plugs seem to cost more then a lot of other bikes. The ones that were for my RC51 were a ton of money while the ones for my R6 are the same price as any normal plug
    Sep 2006
    Simsbury CT
    Yeah, my bike uses "Laser Platinum Iridium" plugs.
    John
    04 KTM 125SX
    05 CBR600RR
    07 KTM 250XC-W
    Wirelessly posted (BlackBerry Curve: BlackBerry8330/4.5.0.131 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    I've always gone with iridium IX plugs which run about $10.50 a plug
    Be thankful you don't have HRC plugs...
    I stocked up on certain plugs a while back.....maybe things are more expensive than I recall.
    The BMW I mentioned used some kind of silver plugs....again, this is going back some years.
    If they were iridiums and not damaged should have just cleaned them
    spray with carb or brake cleaner
    If still looks funky then tooth brush with abarasive cleaner (comet etc.)
    rinse GAP and ride
    Glen Beck is John the Baptist
    who knows
    Thanks for the heads up on the plugs.. My 05 has 7k on it. when are the plugs supposed to be changed on a bike? my car's go for 50 - 60k but i have no idea about this shit. maybe I should be changing those more often? I use the Iridium 4's from Bosch
    Quote Originally Posted by richw View Post
    rinse GAP and ride
    Thought you werent supposed to gap iridiums? Cant that damage the electrode? Id imagine it would be the same for hitting with a cleaner like comet.
    Quote Originally Posted by scubasteveRR View Post
    You might be due. It depends on how you ride. Some bikes respond better to newer plugs then others. My RC51 would liven up a lot with the change after about 4k
    who knows
    Looks like another thing to add to the long list of Winter upgrades and maintenance
    The point (pun intended) is the iridium wire electrode is hard and high temperature enough so that it can be a thin wire and still hold up.
    Electric fields like to leap to and from points where the flux is concentrated. So the thin wire point creates a consistent hot spark from a known position requiring less power to do so.
    If the insulator is clean so electricity can not track down the surface and the gap to the electrode is within specs your there.
    I am sure Iridiums in water cooled motorcycles should last 10's of thousands of miles like 30K.
    However both the spark plug cap, cap resistor and spark wires are now probably a bigger wear parts than the plugs themselves. Check the resistance on your caps and wires and you may be surprised.
  1. Spark plugs recommendations?
    By kumpy in forum Bike Maintenance
    Last Post: 09-06-12, 12:39 PM
  2. Spark Plugs 06 R6
    By BrianC in forum Bike Maintenance
    Last Post: 07-19-11, 07:32 PM
  3. How do these spark plugs look?
    By Punjistick in forum Bike Maintenance
    Last Post: 04-02-10, 08:13 AM
  4. Spark Plugs
    By akira700 in forum Bike Maintenance
    Last Post: 10-10-08, 08:18 AM
  5. spark plugs
    By oreo_n2 in forum General Bike Related
    Last Post: 04-14-03, 07:32 PM
