My Chimney has no flue liner
    Posting Freak Sidewinder's Avatar
    Nov 2004
    NH
    My lake house chimney has no flue liner it's ony brick, what are my options can I use a stainless steel piece or do I have to have one installed.
    I've checked google not to many people have run into this situation.
    What are my options?
    Re: My Chimney has no flue liner
    If the inside dimension of the chimney is large enough, you can sleeve it with a stainless liner.
    How is the camp coming anyways?
    I'm thinking you should host a winter party/ice riding get together
    Lifer burnham's Avatar
    massachusetts
    If someone here doesn't know, someone here http://www.hearth.com/econtent/index.php/forums/ will.
    Edit. R7 is fast.
    I put a flexible SS liner in my parent's wood stove chimney a couple of weeks ago. It was very easy. I used a grinder to cut it to length after is was in place. Lemme know if you need any advice.
    :IWS:
    Nov 2004
    NH
    Mark and Stoink
    Do I sleeve the entire chimeny or is there a box that tapers to the diameter sleeve? Not sure how above the damper it slims down to the small 8" sleeve.
    The chimeny is 14" x20" roughly. So any size should fit.
    Mark its coming along slowly I'm doing all the work on weekends I'm at the finish stage Electrican and plumber are up next.
    I'm going to try and winterize it I bought some 6" foam boards to wrap under the house.
    You can get a kit from Homedepot tell them the size if they dont know tell them to go into there peabody/slantfin catalog. Its near the back half of the pages... alls u need is 2 people to install on on roof one inside house... only know this because i had to sit threw a 2 hr meeting about it
    Nov 2004
    NH
    Thanks I'll give depot a try, 2 hr class on it? What do you do for a living?
    Doug, theres a company, I can't remember the name that does chimney flue liners
    I've seen it done, they go up on your roof, insert a sock is inflate it with pressurized air, then they pour a masonry type liner, let it harden and remove the sock
    Nov 2004
    NH
    Randy If you remember the name let me know I've heard of the process but have not seen a company that does it.
    The liner I used had a thimble for the 90 degree turn where the wood stove connected to the chimney. I put a 3 foot section of ridgid SS liner below the thimble. I hope this answers your question.
    Quote Originally Posted by Sidewinder View Post
    Abundant Life on route 4 in Chichester does linings...
  1. How to wash helmet liner?
    By Hauptman in forum General Bike Related
    Last Post: 08-07-09, 12:01 AM
  2. Adding to existing Chimney Any Masons?
    By Sidewinder in forum Off-Topic Stuff
    Last Post: 04-28-09, 02:39 PM
  3. Replies: 3
    Last Post: 11-29-08, 06:55 PM
  4. Prices for a Chimney
    By TheIglu in forum Off-Topic Stuff
    Last Post: 11-28-07, 10:15 PM
  5. Opinions on Joe Rocket Dry Tech Liner
    By ChicknStripEatr in forum General Bike Related
    Last Post: 09-06-06, 09:12 AM
