Results 1 to 19 of 19
getting rid of oil stains
    boom shackalaka catch2otwo's Avatar
    san fran
    Is there a product to get rid of oil stains on concrete? The parking spot I have has a ton of oil stains from whoever lived there before and that just really gets to me. anything I can "wash" the concrete with?
    Re: getting rid of oil stains
    Simple Green and a power washer might lift them?
    Straight cash homey Pittenger5's Avatar
    Austin
    Brake cleaner
    Senior Member klepsta's Avatar
    Feb 2008
    Stoneham
    Lots of concrete etching compounds that you use before you put down epoxy, Try this stuff maybe http://www.seal-krete.com/osr.htm
    Has a Face for Radio Jim's Avatar
    matches?
    Lestoil - the stuff works great. 2nd place for me would be simple green.
    Start with kitty litter... really grind it in there with your feet... Works better than you'd expect. Clean up what's left with solvents.
    What actually works friggin awesome is the material inside sheetrock. Someone had recommended it to me and I tried it with an old piece I had lying around. It lifts the oldest oil stains really well.
    Lifer obsolete's Avatar
    Norf Sho
    Gypsum, I know where you can get a ton of it.
    Stu P. Daso Wishbone's Avatar
    Jul 2006
    Dave's insanity sauce
    san fran
    no shiznit. we got tons of scrap drywall at work. sweeeeet
    There's a special heat gun that's made for this. I've seen pavers use it and I know I saw one for sale at Home Depot in the past.
    When you heat up the tarmac, the oil rises to the surface. That's when you throw down your Speedy Dry or other absorbant material.
    Top Banana DuncanMoto's Avatar
    He said concrete man concrete.....
    It's going to be the same outcome.
    IF it gets rain....
    kerosene will move lots of it relatively safely
    Then dawn about 50/50 with water spay let soak in or srub with very stiff brush
    do it a day before a big rain storm ...SSSHHH!
    You might finish the tough ones with carb cleaner spray and bloking
    Uxbridge, MA
    speedy dry and your foot.
    Oil Stains????... Is that what they are calling it now a days...
    Well, after more research I discovered that "micro organisms" is the answer and not heat. Guess that's only used for oil on tar...
    Micro organisms
    Another method
    Yet another method
    bergs is so smart and dreamy
    Oct 2004
    Southeastern Taxachusetts
    put oil all over the rest of the floor
