Results 1 to 25 of 27
Trailer Build
    Trailer Build
    some of you have heard me mention that i'm building a trailer. with recient threads asking about pictures, I figured I'd post up the one I'm building.
    A buddy of mine found an old rusted trailer with rotted plywood on the floor. We were able to snag it up for cheap $$$, and started to rebuild it.
    Stripped all the rotted plywood and began to sand and grind all the rust off to get a smooth clean metal.
    Attachment 21273 Attachment 21274
    painted the fenders
    Attachment 21276
    put new 5.70 x 8 michelin tires on & painted the wheels
    Attachment 21275 Attachment 21277
    installed the floors & began the walls. then put new tapered bearings in & installed the tires
    Attachment 21278
    put a spare tire bracket on the frame. also painted both sides of the spare tire
    Attachment 21280 Attachment 21281
    cut about 2 feet from the front and installed a new tongue & safety chain
    Attachment 21279
    installed new LED tail lights
    Attachment 21282
    Ran wiring through the center frame. In case anyone wanted to know what I used for wiring, bought 18 feet of this pre-insulated stuff
    Attachment 21283
    installed Condor. placed spacing for fuel jug walls (to be built)
    Attachment 21284
    will post more updates when i finish it this weekend.
    Re: Trailer Build
    Jim, you have some nice hand.
    Wait! That's not your hand.
    Nat Pixon! noxin's Avatar
    Apr 2008
    Boston, MA
    Re: Trailer Build
    Spend the 30 bucks for the the trailer jack. It makes it so much easier to move sometimes.
    similar to this, http://www.jcwhitney.com/swing-away-.../p2004433.jcwx but I think Harbor freight has a cheaper one.
    Re: Trailer Build
    pat, they had them at the trailer store i went to. i thought about it, but i'm on a budget right now & didnt see the need for it. the trailer is relatively light and shouldnt be an issue to pick up and wheel around
    Apr 2008
    Boston, MA
    Re: Trailer Build
    It came in really handy when I had to single-handedly push it up and over a grassy hill in my backyard.
    Nov 2007
    Re: Trailer Build
    Wow, nice work Jim!
    Quote Originally Posted by DBKromz View Post
    Have you tried it when there's a bike or two on it though?
    Might be worth the extra money in my opinion. I think you can get a decent light duty trailer crank jack for like 50 bucks
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Trailer Build
    Nice work Jim.
    Posted by Jane in BoxChat
    Re: Trailer Build
    update
    disconnected all the temp wiring (twist caps) to run grimmets in the frame holes for the wire routing.
    Attachment 21459
    all connections now have been tinned, soldered, heat shrunk, and then insulated or wrapped. reused spare insulation & zip tied together.
    Attachment 21461
    ready for NHMS
    Attachment 21462 Attachment 21463
    so my bolts mounted behind the tire to hold the fender up apparently was chewing up my tires. Thanks for those who helped me outside of NHMS this week. I just replaced the tire & fixed the bolt issue. The bolts are now on the outside fender holes (far away from the tire) and used zip ties for the center bolt. Nothing I could find would have enough clearance to not rub the tire for teh center bolt.
    Attachment 21460
    Re: Trailer Build
    and yes that bolt with the black head was the one rubbing the tire that blew up on rt 106.
    Uxbridge, MA
    Re: Trailer Build
    looking good there jim. i gotta get mine together for when i...
    oh wait, never mind...
    Secoast NH
    Re: Trailer Build
    [QUOTE=Jimmy 2 Shots;944903]update
    ready for NHMS
    Nice!
    Re: Trailer Build
    My .02 Jim, I would back up those zip ties on the fender with some safety wire.
    Ya done good tho. It looks great in person.
    May 2007
    Southern NH
    Re: Trailer Build
    Muhammad Ali.
    Wirelessly posted (BlackBerry Giggity: BlackBerry8330/4.5.0.175 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/104)
    Quote Originally Posted by bergs
    Will do
    Lifer R1's Avatar
    Somewhere you dont know...
    Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_0 like Mac OS X; en-us) AppleWebKit/532.9 (KHTML, like Gecko) Version/4.0.5 Mobile/8A293 Safari/6531.22.7)
    Whoever did the wiring did a damn fine job. I heard they were a hack but those pictures prove that wrong.
    Looks good Jim.
    Re: Trailer Build
    paul, the more i think about it, the more i dont think i'll need to. the front and back fender holes are bolted up. so even if one of those bolts broke loose, the two zip ties in the center would act as a backup. just having a metal wire that close to the tire makes me nervous. i know the safety wire wouldnt break, but there's very little clearance between the tire and that trailer side.
    Re: Trailer Build
    holy hot sex, that came out awesome!
    with the new tires and wood, was it cheaper than a HF trailer?
    [useless noob comment] you couldn't countersink that center bolt?
    Just Registered drop's Avatar
    Bradford, MA
    Re: Trailer Build
    nice job jim, trailer looks great.
    what was your total material cost?
    - Jamie
    2009 K 1300 S
    Lifer obsolete's Avatar
    Norf Sho
    Re: Trailer Build
    Damn, that's a bunch of work and it looks great.
    Good job, now you can do your snack shopping in 2 trips!
    -Alex
    Re: Trailer Build
    yes, about 1/2 the cost. but there was a good amount of free labor used to prep, paint, and build everything.
    Silver Bullet Commuter fjrrider RI's Avatar
    Narragansett, RI
    Re: Trailer Build
    I am a big on trailers still own 3 just got rid of one. The one I had to give to the auto recyclers after using since 1978 and finally gave up on still runs. kudos for saving a perfectly good trailer looks great now and u will get many years service. Nice you made a light one easy to tow!
    Yamaha lover
    High maintenance priss
    Re: Trailer Build
    Glad the spare held up for the rest of your trip; fix looks good. If possible, ya might be able to send a bolt thru the fender itself at the 12o'clock position to beef up the mounting (instead of using that middle tab).
    That scissor jack works easier w/ the handle, doesn't it?
    Re: Trailer Build
    the 12 o'clock position on that fender would go through the wood side walls, and not the outside metal frame of the trailer. i'm sure those two outside bolts wit the zip ties are plenty enough to hold up those fenders
    Re: Trailer Build
    Update: Jim still hasn't put a jack on the trailer
    Trailer Build-imageuploadedbytapatalk1406750170-237977-jpg
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Trailer Build
    thanks for the update
  1. Track Trailer Build
    By loudbeard in forum Pit Area
    Last Post: 03-23-15, 10:52 PM
  2. winter project - track trailer build
    By isaac_ in forum Pit Area
    Last Post: 01-06-15, 11:42 AM
  3. Replies: 19
    Last Post: 08-22-14, 10:03 AM
  4. FZR 600 build
    By jbmass in forum General Bike Related
    Last Post: 03-06-12, 03:25 PM
  5. Someone build.....
    Last Post: 09-16-08, 08:52 PM
