Page 1 of 7 1234567 LastLast
Results 1 to 25 of 173
Basic Motorcycle servicing and maintenance day.
    This will be the official thread for the basic motorcycle maintenance and servicing day at my house in Taunton, MA.
    Im open to suggestions on dates for this but obviously a Saturday or Sunday.
    Available dates
    August 3/4
    August 24/25
    The aim of the day.
    To provide a hands-on self-taught environment for a group of NESR members to learn some of the basic to mid-advanced techniques and procedures for maintaining and servicing their motorcycles.
    I will endeavor to provide all of the tooling and documentation needed. Space is limited and I would like to have 2 other "facilitators" to help out and a maximum of 8 "students".
    This class is not intended to be a "get your valves adjusted professionally for free" day. I will perform a "how to" on various procedures and you will have space and tools available to then practice the technique on dummy setups (engine in a stand, etc) and if there is time, to perform the procedure on your own motorcycle, with guidance/supervision.
    The format will evolve according to who signs up, but I expect we would run 2 groups.
    Group One would be for people who have never turned a wrench on their bikes. This group will cover:
    Basic motorcycle pre-ride checks (10 mins class, tops)
    Motorcycle tools, including torque wrench and t handles etc.
    Oil change
    Air filter check/change
    Checking/replacing brake pads and fluid
    Front and rear wheel removal and reinstallation
    Coolant change
    Clutch cable and throttle cable adjustment
    Basic motorcycle electrics
    Basic 4 stroke engine technology
    Fi versus carbs, airflow / exhaust changes.
    Group two would be for people proficient with the above basics and will cover:
    Chassis -
    Front and rear suspension removal/reinstallation
    Swingarm removal/reinstallation
    Steering head and wheel bearing replacement
    Operation of tire machine
    Engine
    Clutch removal/replacement
    Valve-cam lash check/adjustment (in line 4, shim under bucket, chain driven cams)Camchain tensioner lifters
    Semi-advanced 4 stroke tuning techniques
    If you want to adjust your valves, you MUST have the bike at my place EARLY. The engine must cool down for at least 4-6 hours BEFORE adjusting valves. I will have valve shims here for exchange if needed.
    If you want to change bearings, you MUST bring bearings with you so we can freeze them for a few hours.
    I have 1 lift, a few stands and limited room. Some of you may end up here all evening due to time/space constraints. The bike lift will be utilized by basic in the morning and advanced in the afternoon.
    I will have a 2005 CBR600RR motor on an engine stand for valve lash class/practice.
    Class attendees will need to bring any supplies/consumables they wish to change WITH THEM or mail them to me prior to the day OR have me obtain them and reimburse me on the day.
    All attendees will go home with a set of JIS screwdrivers. The more of these we can get out there, the less buggered screws there will be on bikes (thanks for the idea NHBUBBA).
    I will provide refreshments. I also have a small in ground pool to cool off in. We will stop for an hour for lunch.
    Suggested donation for supplies, lunch, screwdriver set, expertise.
    Basic = $50
    Advanced = $100
    Amounts donated will not be shared with other attendees. If you don't want a JIS screwdriver set, drop your donation by $25. There is no minimum, but don't be a cheap prick :-). If you are a starving student or unemployed, I will understand. Don't arrive on your Panigale and tell me you're broke though.
    "facilitators" will each receive a JIS screwdriver set and refreshments for their time.
    Leave any attitudes at the door. Bring your sense of humor.
    My house is firearm-free. If you want to carry concealed, you had better keep it concealed or you and I will have a problem. I love guns, but I don't allow them in my house.
    I suggest you bring.
    A flashlight
    A service manual for your bike if you have it
    Stands if you are trailering your bike
    A good set of feeler gauges if on the advanced course. Make sure they go down to .002" if possible. Try to either but the really long ones or the angles ones. Short straight ones are useful only for making tables not wobble.
    Bring your torque wrench if you want to check it against my calibrated torque wrench.
    First 4 to sign up per group will get the spots. CEO and Jimmy, you don't count. You will be facilitating and using your bikes to teach.
    Put your screen name, real name, class you want and any date you cannot attend.
    Re: Basic Motorcycle servicing and maintenance day.
    Jesus. the forum fucked up all my spacing. I'll try to edit it.
    Internet explorer sucks. Screwed up the format and wont allow me to save an edit. Switched to Chrome and all is well. Bill Gates, you suck.
    Member daisha's Avatar
    Norwood, MA
    In for beginner! I'm free the first two sets of dates.
    Screen name/real name: daisha
    Class: Aug 3/4
    Unavailable: Aug 24/25.
    Bike: 2006 Ninja 250
    Edited to remove 17/18 & add bike
    Lifer virtualbong's Avatar
    Metrowest - MA
    Are both groups meeting on the same day? It would be great to join Group 1 one day so that I am ready for Group 2. Either way, thanks you Derek for doing this! This is exactly what I need as I would rather learn myself on how to maintain my bike. I added my type of bike just in case that matters.
    Screen name: Virtualbong
    Real name: Wilson
    Class: Both if possible
    Unattendable Dates: Aug 3/4 and Aug 25
    Bike Model: 2008 Ducati 848
    Will, knowing you, I suggest signing up for the advanced and we will play catch up to get you the basics. The classes will be on the same day as my time is extremely limited. As long as you dont intend actually adjusting your valves that day, there will be time for you to catch up on both classes.
    I took august 17/18 out as that is a race weekend and chris and jim wont be available.
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Great Idea Degsy.
    Screen name: Billy
    Real name: Billy
    Class: 2nd group for Engine
    Unattendable Dates: All weekends in August are open for me
    Bike Model: 2006 GSX-R 750 2012 Kawasaki Z1000
    I dont need anything done on my bikes. Just want to practice on "dummy engines". Is harassing Jim encouraged?
    we do a bunch of these out in socal...
    I recommend:
    -bringing a grill and chicken!
    -your local detailer (landrics?) can detail the bikes for $35/pop
    May 2012
    Screen name: pontifex
    Real name: Ivan
    Class: Basic
    Unattendable Dates: none
    Thanks for doing this Degsy. Hopefully you will do another advanced after this round so I can take that as well.
    Would paypal in advance be preferred?
    Jun 2012
    Westborough
    Screen name/real name: Karate.Snoopy / Nitin
    Class:Basic
    Dates: Aug 24/25 (baby expected in Mid July so early Aug3/4 might be tough but doable)
    Bike: 2007 Yamaha FZ6
    Id love to help out but I'm teaching msf both those weekends. If the dates change let me know.
    Back on 2 wheels yay StrayNut's Avatar
    Aug 2011
    NW Boston burbs
    Screen name: StrayNut
    Real name: Alyssa
    Class: Advanced (I wouldn't call myself "proficient" at the topics in Basic, but I can muddle through, and will be replacing the clutch this winter)
    Unattendable dates: none of the ones listed
    Bike: 1989 Honda CB-1
    Maybe scottie can come down and help facilitate. :-)
    The 25th is my anniversary, but if I'm around, I'll gladly come give a hand.
    Probably Saturday, that is...
    Excellent chipper.
    You'll be asking hardcore to help out too I assume?
    Shit like this gives me the warm 'n fuzzies. This is a really solid thing to do.
    May 2010
    Somersworth, NH
    im pretty proficient with turning a wrench and working on my bikes but id be willing to come down and lend a hand with the basic peoples if needed but will not 'participate' as to leave space open for others who need it more than I do. I could also bring a pad rearstand, a spool rear stand and a triple tree front stand with assorted pin sizes if needed
    Screen name: lord1234
    Real name: Leo
    Class: Basic
    Bike Model: 2008 Yamaha FZ6
    Great Idea Degsy.
    Screen name: IMSTuner
    Real name: Jeff
    Class: Group two
    Unattendable Dates: All weekends in August are open for me as of right now.
    Bike Model: 2008 Yamaha R1
    I might need to mount 2 sets of tires and might need to mount my Ohlin forks and shock.
    Degs, you know I'm in. I'll bring my race tool kit as well and am happy to help grill, cook, or any other 'facilitation' ahembackrubsahem that is required.
    I HIGHLY recommend folks label any and all important tools you will be bringing to avoid ANY confusion.
    Last thing we want are people heading home and realizing they're missing stuff. Just a thought.
    CCS/LRRS #83
    Uxbridge, MA
    I lost a bottle of Captain Morgan there once... I knew I should have put my name on that shit!
    Apr 2011
    Rockland
    Screen name: 7UPyours
    Real name: Martin
    Class: basic
    Unattendable Dates: either weekend works for me,
    Bike Model: 05 Yama fz6
    Dec 2011
    Marlboro
    Name: reks95 / Rick
    Group: Basic, although I'd like to hang around to at least see valves done
    Dates: All are good for me
  1. Not servicing Mass at this time.....Insurance BS
    By Duffy in forum General Bike Related
    Last Post: 03-24-09, 07:26 AM
  2. MSF basic rider course
    By getaddicted in forum General Bike Related
    Last Post: 06-06-08, 09:28 AM
  3. SV650 basic maintenance
    By Murphy_101 in forum Bike Maintenance
    Last Post: 06-20-07, 05:21 PM
  4. Today's lesson in motorcycle maintenance
    By Honclfibr in forum Bike Maintenance
    Last Post: 02-24-05, 10:22 AM
