Where to rent bearing press
    I'm installing new bearings in my front and rear wheels. I've seen the whole oversized socket install method, but would rather not hammer my wheels like a gorilla.
    Is there anywhere that rents one of the mechanical bearing presses that goes through the center of the wheel?
    Re: Where to rent bearing press
    Autozone or advance auto might. Alternatively, you could make one with threaded rod, nuts and washers.
    12 ton shop press at harbor freight- $130
    One other thing to add. If you leave the bearings in a freezer overnight and leave the wheel in the sun for a couple of hours on a warm cloudless day (or heat it in an oven, or with a heat gun), the bearings will almost fall into place in the wheel.
    I'm gonna try the heat gun and freezer trick to see if that helps at all. That's a pretty good idea
    There's another method that involve a snatch block, 15 feet of proof coil chain, a backhoe, a wheelbarrow and sturdy tree, but the heat and cold method is probably easier.
    Senior Member gamorg02's Avatar
    Jan 2010
    cny
    Quote Originally Posted by LXnastynotch93 View Post
    Got friends at a local garage? My local [car] mechanic said i could use his 20-ton if i ever needed to, however the freezer/heat method works pretty well for me.
    Quote Originally Posted by stoinkythepig View Post
    that'd be cool if they did but I don't believe they do last i checked.
    i wanted the 12 ton myself but realized the distance between uprights was like 16" (IIRC) or small enough to not make sense for most wheels, have to goto the 20-ton HF one to get 19" i believe.
    it works really well, they still might need to be hit with a hammer/socket, but if you have the right size driver and use the old bearing inbetween it should go right in.
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    I've heard of this method but it's a hassle to setup. Old school but works slick. Stick with the heat and freezer method though.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Yep after looking, the 12 ton is 16.5" so that won't work.
    I have the 20 ton in my shop also, good unit for the money
    Concord NH
    I've got a couple of presses on our assembly floor right now that could probably completely flatten your wheels if you'd want to use them. I work at Greenerd Press.
    Most small shops have at least an arbor press kicking around. As long as the throat on the press is deep enough to reach the center of the wheel, that would work best. I'm sure someone would do it for just a few bucks.
    Lifer SprintPoser's Avatar
    Apr 2002
    Wow, great to hear you work there, as I thought they were gone for good.
    Greenerd has always made the best damned arbor presses out there, and I lust for a Greenerd No.3-1/2.
    I have a Greenerd #2 mounted to my work bench. Nice tool.
  1. drill press
    By wookie in forum Pit Area
    Last Post: 05-05-08, 09:33 AM
  2. Press release from VIR and AMA
    By Degsy in forum General Track Day Talk
    Last Post: 03-12-05, 04:02 AM
