Results 1 to 14 of 14
Long shot, need some R-12
    I need at least 1lb of R-12 refrigerant for an old auto AC system. I had the system charged in my 71 chevy, the system takes 2.75lbs, the guy only had 2lbs left and didn't know when..or even if he'd be able to come across more. The ideal thing is to find one of the small containers it came in back in the 70's, I think they were 1 or 2lb containers...or to find someone that has it and can add it to my AC system.
    Let me know what you gots
    South Shore
    Re: Long shot, need some R-12
    You should be able to just change the fittings and use 134 no?
    CCS #31
    Quote Originally Posted by MaRce1o
    As a last resort, yes. But everything I've read on the c10 forum, the R-12 works better, and I also upgraded a few parts already that are R-12 specific.
    Lifer Falko's Avatar
    MoonTown
    You can get R-12 substitute through Enviro-Safe. Should be able to add to your existing system, but would want to check on that.
    South Shore
    I definitely agree with R12 being better
    CCS #31
    Bump!
    It's all over ebay, but I can't buy it without an EPA license.
    Ense petit placidam sandman's Avatar
    sema
    Bump!
    how much dose to cost for 1lb?
    jim
    "Molon labe"
    Quote Originally Posted by sandman View Post
    It's about $35 for a 12oz can
    Finally got this sorted. I called a friend that service my house AC last year, and he had about 30lbs of it. Stopped by today and he topped off the charge (took 3/4lb) and adjusted the pressure switch. Felt nice to drive home in ice cold AC.
    Total cost, a case of beer
    Nov 2007
    Glad you got it sorted out.
    General question, why is the older stuff preferable?
    Less enviro-friendly means it works better?
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Posting Freak caddydaddy's Avatar
    Harlingen, Texas
    New stuff doesn't work as well in old systems.
    http://www.griffiths.com/achelp/achelp3.html
    2017 Triumph Rocket III Roadster
    Cages: 2007 Jeep Grand Cherokee 4x4 Diesel, 2005 Escalade
    The way my friend described it to me today, it's mostly because of the compressor style and valving sizes in older vehicles. R12 and 134 both work at different pressure settings, which normally isn't adjustable. Mine was adjustable because I put the adjustable switch in it to make the compressor cycle like a newer vehicle, rather than run 100% of the time
    Member gene03079's Avatar
    Salem NH
    Just found a 30lb tank of R-12 in the garage.
    Flush it down the toilet before they find you.
  1. A long shot - OEM Infinity G35X S wheels
    By butcher bergs in forum Wanted
    Last Post: 09-02-12, 12:16 PM
  2. Replies: 1
    Last Post: 01-30-10, 06:46 PM
  3. CBR600RR stuff needed.. Long shot
    By Degsy in forum For Sale
    Last Post: 04-09-07, 03:45 PM
