Results 1 to 25 of 25
Pulling My Hair Out - 1997 GSXR1100W
    Feb 2012
    Does this bike sound like it's running on all 4?
    I cleaned the fuck out of the carbs, brand new OEM fuel petcock, fresh oil, 4 new spark plugs. It just seems off and I'm going nuts trying to figure it out.
    Thoughts?
    Thanks
    Too many bikes to list
    Mosdt likely drunkd
    Addict jbmass's Avatar
    Nov 2010
    Warwick, RI
    Re: Pulling My Hair Out - 1997 GSXR1100W
    feel the headers/exhaust manifold, see if all four pipes are hot.....
    Feb 2012
    The bike's rocking a rare full twin Kerker set up and the air feels equal. I need to acquire a temp gauge, I ain't grabbing no inefficient 1100W headers. These bikes make heat like an atom bomb.
    Mosdt likely drunkd
    Use a cheap IR temp gun, works great for me.
    Or yank one plug wire at a time.
    Old and Slow Sheppo's Avatar
    Westford, Ma
    wet rag and listen for the hiss...that will atleast tell you if you're hitting on all 4
    Posted by Jane in BoxChat
    Lifer ZX-12R's Avatar
    Candia, NH
    Or a spray bottle with water. Hit all 4 headers and see which one takes the longest to evaporate.
    Hire 4 prostitutes. Whichever one is still bangable after.... Well you get the idea.
    a squirt bottle will tell you for sure
    its in my blood
    Jan 2012
    I hAd a 95 yzf 600r that was running on all 4 but sounded shitty.. when accelerating it would not bog down but had no sack. I found 1 of the 4 carbs didn't have the secondary diaphragm seated correctly so it wasn't working under vacuum. The way I figured it out was by pushing up the piston on each carb. 3 were identical, the bad one went up and down with no resistance at all..
    Member THE STUFF 187's Avatar
    SWANSEA MA
    The diaphragms in top of those carbs always rip & the intake boots always crack as well. Check those things & make sure you have spark. Also make sure when you cleaned the carbs you took the fuel screws out & cleaned behind them as well.
    Adrenaline Cycle
    Swansea,MA
    Dyno Jet Tuning Center
    Apparel
    Fabrication
    Powder Coating
    Paint
    Service
    Engine service
    Race Bike Prep
    Used OEM Parts
    Track bike rentals
    ADRENALINECYCLEINC.COM
    Like us on Facebook
    [IMG]http://www.facebook.com/AdrenalineCycle1?ref=hl
    Hire a few guys and lift...nevermind
    I'm going with spark plug wires. Replace those & your problems will go away...
    60% squid duganc1717's Avatar
    Dec 2008
    Framingham
    Definitely sounds way off, running on three cylinders? I had the same bike with a full Yoshimura system, mine ran like crap also......
    Make sure you replace the spark plug boots too!
    its in my blood
    Jan 2012
    are the plug wires easily accessible ? if so there is an easy way to kill the spark on each cylinder to see which one is skipping.. you take 5/8 fuel line.. cut about 4, 1 inch sections.. put those over the plugs and then put the plug wires back on.. what that does is still allow the plug wire to deliver spark. then ground your test light and stick the other end into the fuel line.. the spark, if any, will go thru your test light and that will kill the cylinder.. if you have a skipping cylinder, when you get to it with the test light, the engine sound wont change.... see what im saying ? I do it on cars all the time to find a skip but generally motorcycles are not easy to get to...
    Feb 2012
    Pulled the carbs down again and found the pilot jet on #4 was corroding and blocking up. Also cleaned out behind the mixture screws and emulsion tubes with new o-rings. It fired up with out the choke.
    http://youtu.be/yY5c79uHZko
    Still doesn't sound right? Maybe ? I can't tell. I got a heat gun and cyl 4 was on point with cly 1. It blew the ignition fuse after about 10 minutes of idling.
    Mosdt likely drunkd
    Senior Member myzx6's Avatar
    Apr 2014
    Riviera beach fl
    Does it have a jet kit???? My zx6 has a Vance and Hines pipe, when I 1st got it running it felt fairly strong but just sounded like shit, turns out it does have a jet kit but needles were off a clip and one cylinder had shims installed wrong. I properly tuned carb(s) completely changes the engine and exhaust sounds. Did you have your slides apart, somebody already added mufflers atleast so it should be jetted( if not that's probably your problem) if so make sure its set up right. I've learned never to trust a previous owner.
    It's my right to not give you any information on this topic.
    Four-bangers will generally run on 3 cylinders but won't run on 2.
    Disconnect one spark plug at a time while the bike is running. If the bike is really running on 3 cylinders, then pulling one of the working 3 plugs will cause the bike to stall. Pulling the bad plug won't do anything.
    Feb 2012
    Lollers.
    Mosdt likely drunkd
    Apr 2014
    Riviera beach fl
    Where do you find all these project bikes, lol I want a new project bike, but I think you've bought them all
    This should be a sticky st the top of the maintenance page. I have had to explain this to far too many "bike mechanics"
    Haha, thanks mate. I learned this from owning Ducatis with shitty ignition modules. V-twins will actually run on one cylinder..
    Feb 2012
    Quote Originally Posted by myzx6 View Post
    CL man. Gotta be quick with the cash babies.
    So I bought an IR temp gun. Cyl 1 and 4 are now at 600F after a couple minutes. 2&3 are down around 300F. They share the same coil. Hm
    Mosdt likely drunkd
    Swap the coils with each other. If the problem goes where the coil goes, it's the coil. If it doesn't, the issue is somewhere else. I'd probably try swapping (or just replacing) spark plug leads too.
    Don't disconnect the coils with the engine running! This ruins some coils.
  1. lowside at hair pin
    Last Post: 09-01-08, 09:11 AM
