Results 1 to 10 of 10
Helmet date code worn off - Snell Serial # good enough?
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    Looking at buying a helmet and and apparently the date code has worn off
    ...not sure how that happens and that *may* answer my question on age (apparently code wasn't etched onto the d-ring on this model / year).
    If I were able to call in the SNELL serial # and confirm the date of manufacture, would I still be able to get through tech? Would Arai provide some letter stating the date that I could take into tech?
    Hate to pass it up b/c it's an Arai and it's super cheap (because it's got a couple of scratches and guess the owner doesn't know there are people in the racing community that aren't out there to be in shiny new gear).
    Obviously will check the foam to make sure it's not compressed and probably replace the liner....
    LRRS 919
    Senior Member Slowpoke387's Avatar
    Enfield, CT
    Re: Helmet date code worn off - Snell Serial # good enough?
    I'd prob pass on it just because it will be an issue every single time you go thru tech. There's enough to think about at that time w/o having to explain it and show another document that they will prob not accept anyway. Although most Arai's have the date either stamped on the d-ring or into the strap cover itself. Not sure where that code was but you may want to check the strap or the d-ring. You might luck out.
    LRRS #387
    I'd pass on it. It won't make it through tech even if you drag paperwork out.
    F that noise. On to the next one
    Sep 2013
    Ok, ok. Passing. Figure the helmet is way outside the 5 year mark anyways if the date code wore off.
    Just didn't know if maybe the date was encoded into the Snell# I deal with a lot of serialized inventory and often I wouldn't be surprised to find out that the snell # reads something like - First two characters are alphanumeric code unique to each manufacturer, next 4 digits are date in MMYY, last 3 digits are sequential number assigned to each helmet.
    Wouldn't be surprised if that were the case, or to find out that whoever is working tech was trained with that little tidbit of info.
    But, as I said, I'm passing anyways. Lots of other helmets to be had.
    LRRS 919
    May 2010
    Somersworth, NH
    Just buy a brand new HJC FG-17 for $180 and done... snell 2010/DOT approved with a composite shell... I have 2 of these now one for the street and one I race in and love em both!! http://www.ridersdiscount.com/s?defa...&Action=submit
    Sep 2013
    Hmmmm...I loved my corsair V...
    Normally, I'd be a little hesitant to trust my head to something <$200....but if it's SNELL 2010 approved then it's gotta be pretty good, right?
    I don't want to even talk about how much that Ducati branded Corsair V cost me.....when I bought it I planned on using it for many, many years - that's before I considered racing so I didn't figure I'd crash it and I didn't even know they were only good for 5-7 years.
    It does seem a little too good to be true though...so what gives? I have a Scorpion EXO (not snell) that I believe cost me ~$400 and it's got nothing on the comfort, field of vision, and airflow of my corsair V. I don't think there's anything that will keep you cool in pre-grid but once I got going that thing made it feel like somebody flipped the AC on before I even reached the end of the hot-pit.
    I'm sure the helmet brand debate has been beat to death on a previous thread. So I'll look around the forum but am open to any new / condensed information people have.
    LRRS 919
    http://sharp.direct.gov.uk/
    They don't have every helmet made, but they've tested a bunch. There are some low cost helmets that test out very well. If it gets a good rating on SHARP and is track legal I'd be comfortable wearing it. Shoei Quests for example can be found for quite reasonable and are a 5 star SHARP helmet.
    I love my bell. Prior to that I was cheap with scorpion. Probably best cheap helmet out there.
    FWIW, I just bought a Scorpion EXO-400 for $80 from CompAcc to be my trackday helmet. They are discontinued models, but the date code on it was 2012 or 2103, I'll verify tonight.
    http://www.compacc.com/p/scorpion-exo-400-solid-helmets
  1. Wanted - Gear | Snell m2015 helmet
    By DoubleRGirl in forum Wanted
    Last Post: 07-17-17, 03:17 PM
  2. Helmet Selection- snell or ece?
    By Jewcati in forum General Track Day Talk
    Last Post: 02-19-14, 08:20 PM
  3. Dunlop Qualifers date code?
    By kumpy in forum Bike Maintenance
    Last Post: 06-02-13, 06:08 AM
  4. Do you need a new helmet- new hjc snell,dot 49.99
    By 9secondsflat in forum General Bike Related
    Last Post: 12-16-11, 08:54 AM
  5. Helmet, Snell required or DOT-only OK?
    By ZDan in forum General Track Day Talk
    Last Post: 05-13-09, 08:32 AM
