Results 1 to 8 of 8
favicon disappeared
    Dublin, NH
    favicon disappeared
    Just noticed the favicon for the site disappeared. Who accidentally deleted it?
    2023 KTM 890 Adventure R
    Administrator Frankenstein's Avatar
    NH
    Re: favicon disappeared
    It's still showing for me in both Edge and Chrome and the file is still on the server. What browser are you using?
    Forum Rules || Stop. Think. Post.
    Update the pointer to the favicon to https in the site css file. Edit, might be in site settings for this forum, it's in the html header of every page so, look there.
    Dublin, NH
    Quote Originally Posted by Frankenstein View Post
    I use Chrome, the latest build. This site is the only one without a favicon.
    *Edit* I noticed when I refresh the page it shows up very briefly but then disappears. Disabled uBlock Origin and still no dice.
    If you're viewing NESR via https, your browser will not load the favicon via http as directed by the html fed out of the site. You can see this by looking at the inspector in Chrome/etc and viewing the 'Mixed Content' warning it generates. If you're viewing the site via http, no issue, you also may not see an issue if you've got a functioning cache of favicon.ico at the moment. This is a change that has been percolating for awhile now.
    Dublin, NH
    Yep, this is the issue. IIRC Chrome defaults all sites to https if available, and if not explicitly set in the shortcut.
    NH
    This should be working now.
    Dublin, NH
    It's back!
