Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_0 like Mac OS X; en-us) AppleWebKit/532.9 (KHTML, like Gecko) Version/4.0.5 Mobile/8A293 Safari/6531.22.7)
Bahahahahahahahahahaha
Anyway check out the Newbie here from Lowell thread in wap. It consistently gives me the "errors found on page" prompt and cuts it out from that point on.
Just something I know is finicky but no big deal
Keith
Quoting?
I only have one phone to test with, but that thread is working perfectly for me.![]()
Forum Rules || Stop. Think. Post.
Yup definitely the answer I expected from a couple of ITguys.
"it works for me, your shit must be fucked. I recomend you stop using that shit before it's really broken"
Jerks
Tapatalk works fine.
Sent from my DROIDX using Tapatalk
Wirelessly posted (HTC EVO "DROID" : Mozilla/5.0 (Linux; U; Android 2.1-update1; en-us; Sprint APA9292KT Build/ERE27) AppleWebKit/530.17 (KHTML, like Gecko) Version/4.0 Mobile Safari/530.17)
You know you can delete that part at the bottom about your phone tapatalk rightOriginally Posted by ssg
whats a user agent string?
sounds like an FBI issued tampon
YES i do want you to start FIXING it... its broken, i know this because when I use it it gives ME problems. As a frequent user i know best how it operates and i can tell you that something is wrong. i suggest you start from the beginning. you should just erase everything and re-install it. but dont do any backups, because obviously as you did the backups and updates i started having issues. my stuff is perfect cuz its MY stuff, and your stuff must just not be good enough to show the actual problems...
here let me suggest this to you....
on a serious note, i found it extremely repeatable where as most times it would happen, then after some time it would go away. thought it could give you a starting point to finding the bug (if it is a bug) but ill chock it up to phone issues or service provider issues....
it may be an isolated incident to my phone. it is however the best phone EVER with the best service EVER and nothing will ever exceed the awesomeness of paying for apps that suck and dropped calls with full service, oh did i mention the OS will freeze from time to time...
bahahahahahahahaha
but seriously, wap is fucked and it dont work right.
What's the ip address of your phone? All I can do is look at the apache logs but I'll need your IP to find any server-side errors that might be related to this. PM me.
btw iphone folk, if your getting this error and you run your phone with cookies disabled when you turn them on the error should disappear...
Thanks for the PM. Apache log says you're a dick.![]()
i think the log is pretty accurate...
Its funny that i always switch between the cookies enable/disable because i find that when i navigate the motorcycle.com owned sites when they are disabled the sites run slow and shitty (ads), so i turn em on and they run a slight bit faster. I typically run my browser with them disabled and was finding the issue to be spotty. that was until today... error (repeatable, repeatable, repeatable) *enables cookies* GONE
Damn users![]()
layer 8 issue from an iphone user? there's something new![]()
Wirelessly posted (i like eating pussy: BlackBerry9700/5.0.0.602 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/102)
Wait I can't find a place to turn this shit off...
