Results 1 to 10 of 10
Subaru to Saab wheel question
    Senior Member tonyd's Avatar
    Jul 2004
    NH
    Any one know how if wheels from a 2002ish Saab will bolt onto my Subaru Outback.
    How close does bolt pattern have to be?
    Sub is 5/100 Saab 5/110 i think.
    How about offset?
    Any help would be great!
    2008 Kawasaki Versys 650
    1972 Honda CL70
    squidness 802er's Avatar
    Feb 2009
    Moretown, VT
    Re: Subaru to Saab wheel question
    You can find specs/offset for your suby here:
    http://www.cars101.com/subaru/tiresa...s.html#outback
    I was looking for some winter rims for my 09 Impreza, ending up getting black steel rims from tirerack.com.
    TWINS! xrocket21's Avatar
    Central Maine
    lol, the bolt pattern doesnt have to be close, it has to be THE SAME
    Westford, MA
    Are the wheels from a 9-5?
    ...I have your pants!!!
    Lifer Danz19899's Avatar
    Grafton, Ma
    Lugs need to be the exact same pattern so u need a 5x100 wheel. . . most subaru wheels i know of are that lug combo
    www.bostonmoto.com
    Ride to live, live to ride
    You need to have the correct bolt pattern, offset, and center bore, since most modern cars are "hub-centric."
    The center bore on that vintage SAAB is 65.1. The bolt pattern is 110mm. Couldn't find the offset.
    I believe the center bore on most Subarus is 56.1mm. The bolt pattern on Outbacks is 5x100mm. Offset for most of the rims is 48-55mm, although there is some leeway there.
    http://en.wikipedia.org/wiki/Wheel_sizing
    Quote Originally Posted by Danz19899 View Post
    05+ STI's are 113.1. If you do the math, that's 4.5 inches.
    Littleton, Ma
    all Saabs under the GM era use a 5x110 bolt pattern (9-2x and 9-7x excluded as they are not Saabs). through the use of "wiggle bolts" you can get away with using them on a pattern up to 2mm off (ie:112 or 108) but 10mm is far to large. ideally you should allays use the SAME bolt pattern as the use of wiggle bolts cause undue compressive stress on the bolt. Also Saab wheels bend like wet pasta so finding a set that are true is a PIA. just buy wheels for your Subaru
    Also if the wheels are off a 9-2x they might work as that vehicle is mechanically identical to the Subaru imprezza
    Quote Originally Posted by Woodsy View Post
    Saabaru wheels are fine, although the offset may differ slightly from standard Outback fitments.
    Northampton, MA
    Just watch out, Saab wheels are about as bend resistant as a rubber band. I replaced 3 of them in the 4 months I owned my 9-3.
    Lifer Falko's Avatar
    MoonTown
    The 9-2X is a Subaru, the wheels should fit.
    The 9-3 and the 9-5 used different wheels than the 9-2X, and are actually different from each other as well. I believe the 9-3 is 5x110 and the 9-5 was 5x114.
    i had to buy new wheels for my previous 9-5 when the factories bent. The 9-3 and the 9-5's were not interchangeable if i remember correctly. My current 9-3 hasn't had an issue, yet.
  1. For Sale - Other | SAAB wheel
    By Falko in forum For Sale
    Last Post: 12-09-15, 09:24 AM
  2. 2004 Subaru Outback Captive Wheel Bearing Replacement
    By JettaJayGLS in forum Off-Topic
    Last Post: 08-26-13, 10:04 AM
  3. Question for the Subaru people
    By lrrs313 in forum Off-Topic
    Last Post: 08-01-10, 10:23 AM
  4. Subaru Outback 17" wheel - 2007
    By TheIglu in forum Wanted
    Last Post: 12-28-09, 06:18 PM
  5. Subaru Service Question...
    By Karaya One in forum Off-Topic
    Last Post: 06-15-04, 07:16 AM
