Results 1 to 25 of 32
Vinyl fencing (install)
    Putting up a 6ft privacy fence, Home Depot vinyl five posts with a 8ft gate.
    Questions:
    1) Rent a single person auger ? Whos used one? or find help and rent a dual one? or shuck it up and just start digging?
    2) Cement vs expanding foam to set them?
    I need to set theses posts 3ft deep plus put some cement (1ft. or so above ground level ) or foam inside the posts for stability and strength. I have steel inserts for the gate posts.. Directions' say I can put cement inside the posts but nothing I have found about foam? Will the foam deform the posts or take the path of least resistance and just go up the tube?
    Re: Vinyl fencing (install)
    I can tell you for sure you don't want to hand dig 5 holes at 3' deep each.
    Augers are nice when compared to a shovel but they will still require a lot of attention for when you likely hit a rock.
    Never heard of foam being used in this type of application.
    Lifer loudbeard's Avatar
    Disagree on hand digging. Post hole digger + San Angelo bar, it isn’t that bad. Use the bar to loosen the soil and loosen any rocks which might be in the way. Result will be a MUCH tighter hole (heh) than you’ll end get with an auger. Also, you won’t wreck you back when the auger jams. I did 60’ of fence 2 summers ago, got my time down to about 20 min/hole.
    Pardon my phrasing....by "rock" I meant "boulder".
    It's the impacted boulders I regularly encounter that yields my opinion. There's no telling what lies below
    Going 3' down, I'm not hand digging. Powered auger at a minimum.
    backhoe, listen to bergs about boulders
    power augers are not any easier than hand digging when you hit a boulder
    I dig 3ft holes all the time (40" to be exact) with a sharpshooter tile spade, but I can move over when I hit a rock, precise placement is not important for soil evaluation, a fence post has to go at the end of the rail, not a foot away
    Vinyl fencing (install)-1605_77621_p1-jpg
    The guy who installed 600 feet of split rail on my property dug all but 1 by hand, he does it for a living. The 1 was a boulder, I used the backhoe for that. Not sure how a powered auger would have helped in that case. He’s only doing 5 holes, I’d have them dug by hand in less time that going to rent an auger.
    my mind is blank, I have forgotten the thousands of granite & concrete property corners I have set, 48" long sticking up 6" = 42" hole, nearly all with a sharpshooter & crowbar
    I'm not suggesting a powered auger is better for boulders.
    What I'm saying is, a powered auger is what I consider to be the absolute minimum for multiple holes that require specific placement at 3' deep and I personally would never hand dig 3' down on anything. Run the auger, find which holes are an issue for depth and go from there.
    Of the general types of land I have worked with, the hassle of hand digging is not worth the effort, IMO.
    South Coast MAsshole
    As was said augers are nice to skip the digging...they won’t help with large rocks...I have very bony soil here...I had an installer install my backyard fence cause I knew how it would go and it was a lot of fence...they did it all by hand with post hole diggers...they racked the fencing cause my yard is sloped but they installed the gates level...I installed my driveway gate and small fence alongside myself...I did this by hand (6 posts)...I also put in 15 sonotubes for my shed and I used an auger...I used a 2 person Home Depot rental auger and it was well worth it...used concrete on the posts I set
    Personally for 5 posts at 36” deep I would just do it by hand...but this really all depends on your level of fitness
    Sent from my iPhone using Tapatalk JJ
    Point37s Garage Sale Thread
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    We hand dig holes for utility poles all the time. I probably wouldn't rent an auger for that job. We also set them with foam sometimes. It doesn't expand in a way that would crush or deform anything, and it's strong as fuck. It's also pretty expensive, I think the kit for a 7' hole I usually use is about $150. If you had everything prepped, that kit would probably do the 5 holes for the posts.
    Looking into using this product for the posts. https://www.lowes.com/pd/Sika-Polyur...B&gclsrc=aw.ds
    I am not totally out of shape yet! So i will see how easy the digging is before i start blasting!
    That's quite a project... would be farming that one out!
    New Haven-ish, CT
    My dad and I re-set my mailbox post a couple years ago. Post hole digger and the bar to shape the hole and loosen the soil, then a shop vac (with filter out) to suck out the dirt and small rocks. Made pretty quick work of it. Hose out the shop vac when done.
    We rented a 2-man augur to dig footings for my deck a while back. I remember that being a big pain in the ass. You’ll need to find a decently strong helper to use those. Definitely seems like overkill for this use.
    daideó Rambunctous's Avatar
    Waterville Valley, NH
    Just plant some rose bushes. Thorny. Easy way out. Natural. Make wine with the roses.
    RIDING THE RAILS
    I’m all for a mechanical advantage, sometimes you can’t replace a strong back and a weak mind.
    Lifer obsolete's Avatar
    Norf Sho
    As the son of a Portuguese immigrant, I appreciate the all back no brains method.
    -Alex
    In good soil, it takes about 10 minutes to hand dig a 3’ hole with a post hole digger. For a fence, I’m not sure why one would go to any effort removing a large rock or boulders, make the hole wider, cut the pole and cement it in
    A Big Powerful Sportbike
    I am digging it!
    In the picture below you'll see a boulder that I ran into on today's job. The rough dimensions of the boulder are 3'x2'x1'. (LWH)
    A fence post needs to be in this location.
    The spec for the hole is 3' deep.
    What is the next step? Cut the post at 9 inches and pour a large swath of concrete?
    Vinyl fencing (install)-img_20210426_103238233-jpg
    C4! All kidding aside I would say that boulder has to come out. Was thinking if I hit something that big at 2'-2' and1/2 I would stop and cut the post!
    If the backhoe is on site, I would dig a deeper hole next to the boulder and roll it in. Line post or corner?
    Sorry, the luxury of excavation is not available on this job site.
    The available tools are the ones mentioned in this thread...a San Angelo bar, a post hole digger and a spade as well as cutting the post down and pouring a wider area of concrete.
    One last suggestion in this thread is to make another hole and dump that boulder into it but again, we're doing all this by hand so how does the plan get executed?
    I thought it was clear, but maybe I need to reiterate;
    When choosing to dig a post hole BY POWER AUGER....or.....BY HAND then I recommend digging by hand. Most people, including professionals, agree with that. Introducing boulders is a different problem, but you already knew that. Not sure why you felt the need to be difficult because I disagreed with using a power auger.
    Lifer virtualbong's Avatar
    Framingham, MA
    On a similar topic, does anyone has a hookup to fence installer in the Framingham area?
    I couldn't care less that you disagreed, Duncan. Based on the advice given here, everyone wants to hand dig and can get the holes done in 10 to 20 minutes. LOL....fine. I respectfully disagree.
