Results 1 to 17 of 17
Driveway perimeter drain
    Northampton, MA
    Should be straightforward. Right?
    Got plenty of 4" perf tube, the sock that goes over it, 6 tons of 3/4" stone being delivered.
    Going to be at the edge of pavement. Thinking 3" of stone, then pipe, then another 3-5" of stone.
    Obviously keep it pitched right.... anything else I'm missing?
    Getting the driveway paved Wednesday. Have a 4' or so curved earthen/fieldstone retaining wall. Want to keep the water from going down the wall and wrecking the pavement. Pavement will go right up to the rock wall if I don't put the drain in. If I do the drain, there will be a 6"-1' gap from rock to pavement where I will have the drain/3/4" stone.
    Re: Driveway perimeter drain
    If I'm visualizing right, by doing it the way yer proposing, it will make things worse, it will allow water to seep into the ground and get under the pavement
    you should have a paved swale at the edge of your rock wall OR put under drains in that will collect any water that gets under the pavement and daylights it at a low point where it can drain away
    Northampton, MA
    That's the point, drains any water that gets under.
    Northampton, MA
    Randy, uploading pictures of the area of concern now, once I post them maybe you can give me your thoughts on best path forward.
    Paving company wants to pave right up to my rock wall, into all the cracks. Problem is, it's just stones laid on grade, then backfilled around. They aren't deep and some are above where the driveway will end up being.
    Northampton, MA
    Rock portion of wall, pavement will go right up to it.
    Northampton, MA
    Rest of the path around the far edge of the driveway. Was going to trench out along the edge, put 3/4" stone, 4" perf pipe in sock, more stone.
    no can see
    the drain has to be under the pavement to get water that is underneath the pavement
    a drain adjacent/beside the pavement will catch surface water and release it into the ground to flow underneath the pavement
    unless you prep the base (under where the pavement is going) with underdrains, best bet is to rely on surface drainage
    what is you sub base & base material, how much processed gravel directly under the proposed pavement
    Also can't see
    Northampton, MA
    Paving company is doing all the base, I was just hoping to prevent any water issues. Think I'll just let them handle it at this point. They are going to strip everything back, lay suitable base material and grade for drainage.
    Driveway perimeter drain-img_2275-jpg
    Lifer 03Worc9R's Avatar
    Worcester, MA
    How did the driveway come out?
    My driveway is a nightmare. Currently feels like Im standing on a waterbed in multiple areas.
    Quote Originally Posted by 03Worc9R View Post
    mine is a bobsled run today
    Northampton, MA
    Eh, they didn't put in a good base. Had multiple spots where weeds pushed through the paving.
    Recycled didn't harden as much as I hoped.
    I bought 100 yards of recycled asphalt for my driveway in September and it never hardened either. Next time, go with reground asphalt, as it doesn’t have gravel mixed in like the recycled stuff does.
    Lifer Stromper's Avatar
    Eastern Ct
    That's a loose wall will let ALL the water from the hill run through
    Would it be too energetic to trench behind
    put a curtain drain and the porous pipe down there
    The calculus of hate
  1. hot water heaters...to drain or not to drain?
    By greenmonster in forum Off-Topic
    Last Post: 01-11-14, 04:23 PM
  2. Drain water
    By a13x in forum Pit Area
    Last Post: 10-14-09, 08:28 AM
  3. VP C12 .... drain it or not?
    By derrickhackman in forum Pit Area
    Last Post: 05-24-07, 08:02 PM
  4. Drain your racebike
    By Paul_E_D in forum Pit Area
    Last Post: 10-14-06, 11:01 PM
