Have an 07 GSXR 600 Track Bike Part Out. If you don't see what you need please ask anyway. I've probably got it. You can get me via pm here or email Chidadog@gmail.com Thanks for looking.
Stock Stuff
Ram Air Tubes…………….50
Front Turns/Mirrors ……………40
Gas Tank Flat Black No Damage…………..250
Small Tank Panels………….20
Fuel Pump…………………65
Rear Turn Signals………………..30
Lock Set Ignition, Cap, Rear Lock…………..125
Clip Ons………………….35 ea
Triple Tree…………………100
Stock Damper………………20
Clutch Lever with Perch………………….35
Front Brake Lever……..15
Front Brake Master………………60
Rear Brake Master………………15
Stock Front and Rear Brake Lines…………10
Rear Rotor……………25
Front Rotor………….40 ea
Front Calipers………………..20/pc
Rear Calipers…………………15
Front Rim ……………………..200
Rear Rim………………………175
Carrier/Hub …………30
Gauge Cluster w 7685 mi……………..150
Front Short Harness…………….45
Rear Short Harness…………….20
Stock Headers………………..60
Muffler……………….40
Left Accessory High/Low Beam……………25
Throttle Accessory……………35
Front Seat……………….25
Swingarm………………..45
SubFrame………………….160
SubFrame Rails L&R……60
Battery Tray………………….20
Black Undertail ……..15
Front Axle………………….20
Rear Axle with Blocks………20
Rear Spacers……….15
Rear Spools……………….10
Shock……………25
Links……………25
Kickstand………………….40
Stock Rearsets…………..45 ea
Shifter Assembly ……….35
Passenger Pegs………….50
Speed sensors……45
Turn Signal Relay…..20
OEM Black/Silver Fairings with Lights Some Rash…………..475
Aftermarket Fairings Maroon/Black……………450
THE GOOD STUFF
K&N Race Air Filter Cleaned and Charged…………………30
Yoshimura Full SS Exhaust w/cat all Matte Black……..SOLD
Vortex Fairing Stay Black……….90
Vortex Black Rearsets………….225
Vortex Gas Cap Silver/Blue Cap……..50
Vortex Black Clipons……………..90
Vortex Black Long Levers……………100
Vortex Black Stator Cover Protector……….45
Vortex Sliders…………………55
Vortex Sprockets 43t-51t………….25 ea
Front Sprockets 14t-17t.....10 JT Black Rear Sprocket 46T……25
Black Keyless Gas Cap………….30
PC Racing Flo Reusable Oil Filter………….50
Motion Pro Revolver Throttle w/4 cams……….90
Pazzo Black w/blue Shorty Brake Lever………50
ASV Black w/red Shorty Clutch Lever……….50
Many other levers just ask…
Galfer Black SS SBK Brake Lines F&R………….100
Many other brake lines just ask…
Galfer Rear Wave Rotor……………65
EBC Pro Front Rotors 3091……………250
Rear Derlin Spools…………20
Woodcraft Sliders…..55
EBC Rear Pads FA419HH NEW in Package…………25
Moto-R Stator Cover……………..75
Woodcraft Stator Cover..............90
LSI Case Protectors…………….65
DD Sport HH Front Pads SDP947HH+ NEW in Package (complete front)……..55
Black Race Rails…………85
Bazzaz ZFI/TC w/Pull QS…………….600
Dynojet PCIII…………….160
Yoshimura Kit Harness…………400
Yoshimura STR-S Cams………….475
Ohlins Triple Clicker Rear Shock…………….600
Front Forks with Penske internals………….300
Front Forks with KTech internals.................300
TRE Haven't seen it yet... possible Bazzaz?.....................................40
Speedo Healer possible Healtech will post type after I see..............50
GPR Black Red V4 rashed and needs base...........150
Hotbodies Fairs SBK Tail Matte Black…………..400
Armour Body SS Tail can’t tell Wrapped and Repaired…..375
Backoff XP Brake Light Modulator……25
Road Racing Forums/Free Natl Classifieds www.motorcycleroadracingforums.com MRRF
You think the Bazzaz and/or the front brake lever would work on an '04 GSXR?
Levers no. Different perch but bazzaz.....hhmmmm might want to check with them. I believe the injectors are the same size. Good question.
