Description from SVRP is below. I'm asking $140 shipped, which is a $20 savings. Part is like new.
Woodcraft Gen 1 SV650 2 piece engine covers are designed to keep your bike tight and prevent oil spills in the event of a crash. It also gives your bike a custom look that really looks the business. Woodcraft Engine Covers are the number one choice of AMA Racers.
Precision CNC Machined from 100% 6061 Aluminum billet gives the solid engine cover great looks and exceptional strength.
The patented replaceable skid plate adds wear resistance in the most vulnerable area and can keep your cover both functional and working the way it should through multiple crashes.
The Skid Plate is internally bolted and uses an O-Ring to seal it so that you don’t have to worry about trying to remove bolts with the heads ground off.
Note: This cover re-uses the Stock OEM rubber O-Ring for the cover.
Skid Plate Colors are Stainless Steel or Double Thick Aluminum in Black, Red, or Blue.
Note: For Gen 2 SV650: All you need to do is swap out the right side engine cover for a Gen 1 Engine inner clutch cover, (it bolts right on without modification), and then bolt the track and race approved Woodcraft Gen 1 Cluttch Cover on exactly like the Gen 1 Model.
'14 Aprilia Tuono - crack on 2 wheels, '14 Ninja 300, '04 BMW M3
