ONLY THING REMAINING IS THE FRAMING GUN. FIRST $100 Takes it!
Or here is the breakdown.
Ridgid 3.25 HP 4.5 Gallon Air Compressor This Rigid oil free twin-stack air compressor. $275
# Motor type: Induction with start and run capacitors
# 120 Volt AC
# Air Delivery: 3.9 SCFM @ 90 PSI
# Pump Type: Oil free direct drive
# Pump Construction: Reciprocating piston with teflon coated rings and extruded aluminum cylinder
# Max PSI: 150 PSI
# Quick couplers: 2 each, universal push style
# Gauges: 2 each, 2" easy to read with metal housing
# Regulator: Fully adjustable ratcheting style
Comes with 50' Hose
Porter Cable Roofing gun. (used for one Roof/Still like new, ) $125 SOLD
Porter Cable Framing Nailer (Used condition, needs recoil spring for holding nails down, but works fine) $135
Campbell hausfeld Impact gun $75 (Sale Pending)
Campbell hausfeld air ratchet 1/2 drive $45
2 Husky Mini Die Grinders $25 Each 1 SOLD (1 Sale Pending)
ingersoll rand Right angle grinder $50 (Sale Pending)
ingersoll rand Buffing/polishing wheel $50 (Sale Pending)
