$1,000.
This car has belonged to my parent since '98 40k miles.
THE BAD
currently the body is none repairable due to a rusted/broken front left strut tower. The radiator core support is also rusted out. The right rear trail arm bushing washer is rotted off and allows the rear tire to move freely front to rear. This car is being sold as none repairable parts car.
THE NOT SO BAD
152k miles, the engine runs fine, doesn't burn or smoke oil or leak any fluids, trans shifts good. T-belt was done around 100K
The rest of the mechanicals are in working order
struts, brake have been replace and have significant life'
tire are stock size with more then 50% tread, wheels have no noticeable if any curb rash.
the exhaust was replace in June with an aftermarket cat and cat back, single muffler. Duals is no longer available.
all interior buttons work, power seats, windows work, radio, climate control etc. AC which has a small leak and blows warm. I'm not sure what the leak is.
See the pics. I have move pictures if you would like them.
The car is not drivable and will have to be picked up with a flat bed. It is located 30 minutes from Milford NH.
Tim
LRRS #44
Superbike Services 44
