1973 Yamaha RD250, 350 conversion. $3,100. Pick-up in Central CT, 10 minutes from Hartford. Partial trade - CT-legal firearms.
o Wiseco pistons and rings
o Wrist pin bearings
o RD350 cylinders and heads
o Crankshaft seals (Japan)
o Crankshaft bearings- outer
o Ultrasonically cleaned carburetors (new main & pilot jets, synchronized)
o Fuel Petcock Rebuilt
o Stainless Allen head engine bolts
o Yamaha factory air filter
o Throttle cable
o Steering bearings lubed
o Front fork seals and boots
o Grips
o Battery
o Seat cover
o Bridgestone BT45 tires (200 miles on them)
o Chain and sprockets
o Spark plugs
o VHT engine case paint
o PPG dark blue metallic, base coat / clear coat
o Rear wheel bearings
o Points and condensers, timing set w/ dial indicator
o Fuel lines & fuel filters
o Turn signals, horn, brake lights all work.
