Results 1 to 10 of 10
2006 ttr125
    2006 ttr125
    1.) Cheapest mini Moto options?
    2.) Comparison to XR100?
    3.) Wheelies?
    4.) Model year differences?
    5.) Which goodies can I swap on this?
    $575...does not run..last reg'd / ridden in 2012
    E start....small wheel...not gonna keep it forever ..just wanna get her running​ on the cheap fo' some stunner days then flip.
    Re: 2006 ttr125
    Not as desirable because small wheel version has drum front.
    Usually it's a carb when it doesn't run, but if it's not you might find yourself underwater on it.
    Ttr has more power and xr always had a drum front.
    Ttr didn't change ever through production really. They were pretty much all the same except for the difference between the ttr125 and the ttr125l.
    Lifer gixxer72's Avatar
    The desert
    Re: 2006 ttr125
    The choke design on those carbs is garbage, and they are incredibly cold blooded. Disassemble the choke from the carb and clean it periodically, they tend to freeze up with gunk and can be a pain in the ass to fix. Jetting helped mine be less difficult to start but didn't make any noticeable performance difference.
    On the plus side, wheelies for miles on that little thing!!
    Re: 2006 ttr125
    Is a disk conversion (with forks) a direct bolt on?
    I know someone pulling the disk brake forks from a ttr to go to a yz85 front end
    And I have an ultrasonic cleaner so I will see how bad the carb issues are
    Also saw from TT that it's a soft built bike...dunno if it's best for #bikelife#wheelies or an adult hooning on it... already broke the kickstart lever
    Will start with the basics, fresh plug, tank of gas, presumably clogged petcock, and charge the battery
    The desert
    Re: 2006 ttr125
    Don't worry about it, they are tanks. I'd rip wheelies on it all the time, never broke anything (I'm 230 lbs) Even did a couple MX laps on it for giggles. I don't recommend that.
    Re: 2006 ttr125
    I wouldn't put much into the small wheel. Get it running, sell it for a few bucks, buy either an L or LE. Or get a real mini and buy a YZ 80/85.
    Re: 2006 ttr125
    The more I look into it, the more that is the consensus...the cost of converting to the L setup (forks/rim, swingarm/rim) is better spent on a yz85. Swapping just the front for the brake requires the rim to swap too...and will make it "sit like a chopper" so I am gonna stick with the drums
    I've had 2 CR80 mini supermotos...rm85...and ns50...kinda done with 2 stroke mini's...just want a fart bike that's easy to ride and less dangerous to whoolie
    Gonna keep it stock and just get it running
    Re: 2006 ttr125
    Not sure what options are on the TTR, but the XR100 comes with a 16" rear wheel. You can swap in an XR80 front wheel which is also 16" and rock a set of BT-45's and sumo on the cheap.
    rides bikes
    Nov 2014
    Re: 2006 ttr125
    Clean the carb, ride the shit out of it, sell it for more than you paid for it. We've had a couple TTR125's for the wife. Big wheel is for sure better, but the smalls are fine too. They're cold blooded and the carbs get gross easy. Not a performance machine, but does its job well.
    Re: 2006 ttr125
    I have had a couple XR100's and an XR80... between exporting and mini Moto the Craigslist price in socal has sky rocketed....$800-$1,200 for a 15 year old 100cc 8hp bike
    Crazy...I bought them for $400...$550...and sold them for $650 and $700 (in sumo trim)... should have kept them, waited a couple years, then sold for $1,000
    TTR has a 17" front and 14" rear...the front is super narrow so most good tires won't fit well. Couple cheap barracudas or other scooter tires with a change at home is all I am willing to invest in it
  1. For Sale - Motorcycles | 2003 TTR125
    By nick5446 in forum For Sale
    Last Post: 10-03-16, 03:50 PM
  2. 2001 TTR125 - 500
    By Awesome in forum For Sale
    Last Post: 04-04-13, 08:35 AM
  3. WTB - XR100/150 or TTR125 - $500 budget
    By Kurlon in forum Wanted
    Last Post: 06-08-12, 05:55 PM
  4. 2001 TTR125
    Last Post: 07-15-11, 05:55 AM
  5. crf150 or ttr125
    Last Post: 07-08-10, 07:18 PM
