Results 1 to 25 of 28
Thumb brakes
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    Thumb brakes
    Does anyone use or have experience with a thumb rear brake on their dirty ride? I've been mulling over the idea since I started riding dirt. My feet at big and uncoordinated and I like to stand on my toes while riding so my rear brakes seem to to get used less than they really should. I see kits for about $300 which would be well worth it if they work as advertised. Any info is appreciated.
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    Re: Thumb brakes
    That seems like a bad idea to me. I think modifying your lever so you can get to it is a better idea. And just learning to shift your feet.
    Lifer JettaJayGLS's Avatar
    Tahoe City
    Re: Thumb brakes
    That shit's for stunters. Grip and rip.
    Re: Thumb brakes
    ive been thinking about this mod as well for my woods bike.
    looked at the Rekluse and one other company (forget the name). they use a finger lever rather than a thumb though.
    Re: Thumb brakes
    I've only seen videos...looks pretty cool
    imho - even if you get feedback from people, you're only going to know if it works by trying it yourself. And unfortunately you're only way of trying is to buy it...so it's a money/risk to "try it out" - I usually don't take that route, so I'd recommend what smutty mentioned
    Fairhaven, Ma
    Re: Thumb brakes
    Yeah I could use a rekluse for similar money before the thumb brake I'm sure. I've rear of some people removing the clutch lever with the recluse and using a rear brake lever there instead. I wouldn't go that route. The internets is full of haters and lovers of it. I don't have any good muscle memory for the rear brake so it should be easy to switch physically. It's also something I wouldn't mind trying on the track bike if it works out for the dirty bike.
    LRRS EX 151 AMSOIL
    Re: Thumb brakes
    the reckluse at least lets you brake without a clutch then you can feather as necessary to power out of any corner, or just straight chug that thing. then there's the clake dual lever...super fancy geek tech thats pricey as can be.
    Re: Thumb brakes
    i was talking about the Rekluse LH Rear Brake Kit ... there is another company i was looking at, feel like they were Australian but cant find the link. maybe it's the dual lever thing Chipper mentioned above. i'll try to find it but here's the Rekluse kit
    http://www.rekluse.com/brake.shtml
    Re: Thumb brakes
    Adjust the brake lever so it's above the peg a touch, and get a stiffer return spring on it. If you can't find one, a washer plus a valve spring on the master can add some return pressure too. That'll give you some feedback in your foot to work against allowing you to 'read' what you're doing.
    Re: Thumb brakes
    I can see a lot of advantages to a hand rear brake in woods/trail riding. Down hill + sharp right hand turn + low speeds... and a 2-stroke are the first things that come to mind.
    I know when I was in Europe a couple years ago, the fast enduro guys all had hand rear brakes...it has to tell you something?
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Re: Thumb brakes
    Not for me.....I feel that when you should be using your back brake you hands already have plenty to do. Clutching, throttling and braking as well as steering input are plenty for your hands to do. Once your skills advance you will be doing all three at the same time.
    Just practice a lot. Learning to modulate the back brake is a great skill to learn.
    Whether you are entering a corner or adjusting front end attitude in the air, rear brake skills are important. Not so much for slowing down but for so much else. Don't get me wrong. You can get a certain amount of braking from the rear but mostly it is tool for steering and attitude adjustment.
    Fairhaven, Ma
    Re: Thumb brakes
    Slightly off topic bump. Left hand rear brake.
    I'm getting no better this year using the foot brake. It's especially bad going down gnarly hills. Generally it causes me to have to sit (or feel like I have to sit) when I should be standing, so I'm entertaining the idea of the LHRB now. I almost ordered one a few minutes ago, the one typeone posted from rekluse, and remembered this thread. Is anyone running that setup? It seems pretty common over on KTM talk. That setup lets you keep the rear foot lever and is thin mounting for use along side the clutch lever. My bike has the rekluse so clutch use is less than normal.
    Thoughts are appreciated
    LRRS EX 151 AMSOIL
    Re: Thumb brakes
    You dont take money risks? Really?
    edit: this was in response to breakdirts post. Forgot to quote him and lost all humor.
    Carry on.
    Re: Thumb brakes
    i go back and forth on this mod all the time... because i'm the exact same way, no good with the rear brake when standing and it drives me nuts. i sit to rear brake. hate it ! totally burned into my mellon for some reason.
    i'm committed to practice more before altering my levers. i started thinking about it this way, i know how to use the shifter while standing, why not the brake. maybe this will help my brain get over the hurdle. not sure. next season will tell. i think it's the way i keep my foot on the peg. the left is fine moving, the right, no-can-do while standing. WTF
    Re: Thumb brakes
    this is an interesting idea. i can see the advantages. i am struggling with the rear brake a little as well. i think the lever may be a bit high though for standing. sitting is OK. with boots on feel is obviously greatly reduced, and when standing i tend to lock up the rear more easily, thus causing me to depend on the front brake a little more in downhill situations. not really what i want.
    im gonna have to save up my pennies for a rekluse, although i must admit how impressed i am with the 300s ability to just chug along at barely an idle and then power out of it. it would still be nice to not have to worry about the clutch
    Fairhaven, Ma
    Re: Thumb brakes
    I still use the clutch. It's not something you forget. I use it mainly to loft the front tire and in whiskey throttle control. Still way less use than stock. It really shines in those sticky situations like when you get to a gnarly, muddy, rock pit or a rooted rocky hill. You know the places you just hate to stall. Also, when you crash and the bike is still running. I called rekluse and found out my brake light switch will still work with their kit. I'm gonna do it!
    LRRS EX 151 AMSOIL
    Re: Thumb brakes
    CHEATER!
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    Re: Thumb brakes
    I don't get why you would have to sit to use the rear brake unless your lever height is way off.
    Coming from a sand/mx background, you damn sure get used to using it while standing, and while coming in wfo over VW bug sized braking bumps where there's no way in the world you could be sitting, because you'd get bucked off the bike. As Adam pointed out above, its needed in the air too, and you can't be sitting then, either.
    All good dirt riders I ever knew had ALL controls set for body geometry while standing, not just the rear brake. One of the most consistent woods riders told me once regarding riding off road fast, "if you sit down, you go down"
    Fairhaven, Ma
    Re: Thumb brakes
    I don't know if the height has much to do with it. It's just something I can't get the hang of. It's uncomfortable and takes a lot of concentration to control while standing for me. Anyway, it may be cheating, but anything to make riding fast safer and easier should be worth it. A lot of people on KTM talk say they will never go back to a conventional setup again.
    LRRS EX 151 AMSOIL
    Sep 2012
    Southwick,MA
    Re: Thumb brakes
    Yeah, I can see how it would make sense, especially in slow tight right handers.
    Back when I was riding a lot of dirt, nobody I knew of ever had a hand rear brake, and frankly the terrain didn't demand a lot of finesse with it...most of the time, (sand mx or tight woods) there wasn't much reason not to give it a solid stomp and let it lock for a second or two, then release it to accelerate out...it wasn't like we were trying to use finesse to trail brake with it, most of the time, but I get that there is always ice riding, or the steep wet leaves downhill, etc, where some finesse is needed.
    Re: Thumb brakes
    we,re talking about technical, steep downhill sections and fast, tight switchbacks. this is where a LHRB (could) would shine.
    Fairhaven, Ma
    Re: Thumb brakes
    Update.
    I got a few short trail rides in and 2 JDay races since the LHRB install. I chose the one from rekluse themselves that uses a MTB master and short lever. It was well worth every cent. It's quickly becoming another bike transforming item nearly on the level of the auto clutch. I kept my clutch lever canted high and the rear brake pedal works like normal. The LHRB has just enough power to lock the wheel, but a normal squeez gives perfect half rear wheel speed. I can't say enough good about it.
    LRRS EX 151 AMSOIL
    Re: Thumb brakes
    I gave it a quick testicle, and I can confirm its radness. It's on the list, right after a refresh.
    Bellingham MA
    Re: Thumb brakes
    When are you guys bolting up the power steering to your dirt bikes?
    Re: Thumb brakes
    Update.
    Haven't researched it, but what does the little gizmo go for $$ wise? I plan to do a lot more riding this year, and this thing may help force me to stand more..and not fall off the bike as much
  1. For Sale - Other | M&p 9 thumb safety nib
    By G21forme in forum For Sale
    Last Post: 07-31-20, 12:24 PM
  2. Riding with Thumb Ligament Tear
    By aprilb in forum General Bike Related
    Last Post: 04-21-14, 08:25 AM
  3. HELP - left handed thumb throttle
    By Kitt in forum General Bike Related
    Last Post: 03-14-13, 12:37 AM
  4. New Brakes
    By alwyzbroke in forum Bike Maintenance
    Last Post: 10-30-07, 08:14 PM
  5. Brakes
    By HBerry in forum Bike Maintenance
    Last Post: 06-30-05, 08:19 AM
