Results 1 to 20 of 20
will either of these master cylinders fit my xr250r?
    Jul 2008
    Marlborough Mass
    its a 1995 xr250r the banjos are 12mm....would one from a 2002 CR250 or a 2004 CRF450 fit?
    Lifer DuncanMoto's Avatar
    Re: will either of these master cylinders fit my xr250r?
    Well all 3 take the same master cylinder rebuild kit if that helps.
    I would make an educated guess of yes.
    Jul 2008
    Marlborough Mass
    hahah well I hope so...just bought one from the 2002 cr250
    only 40$ its worth a shot
    If you need a rebuild kit they're $25 complete with new piston.
    Jul 2008
    Marlborough Mass
    yea i might end up doing that with the stock one if this one from the cr250 doesnt end up working....
    Its just nothing would flow through it....i took apart the internals and they were fine...
    Quote Originally Posted by DuncanMoto View Post
    Do you list rebuild kits for NSR50 rear brake masters?
    Quote Originally Posted by mondos06cbr1000 View Post
    Hmmmm. Sounds weird. The internals do not always look bad, but the rubber can be hard and worn out. Then a small piece of rubber gets stuck in the tiny hole......
    Jul 2008
    Marlborough Mass
    hmmm i brought it to a honda dealer and they took it apart and came to the same conclusion as me...everything looked fine...and then they'd pour fluid in the resevoir and it wouldnt drain out when they pumped the lever
    hopefully this works!
    in case it helps, MotoSport has 'fiche for your bike, could come in handy:
    http://www.motosport.com/dirtbike/oe...250R&year=1995
    Jul 2008
    Marlborough Mass
    yea thats were ive been ordering all the stuff from. I dont necessarily wanna pay 200$+ for a OEM master cylinder if i can get one from another bike that works for 160$ less ya no?
    Thanks for looking out tho!
    yeah, i hear that, no sense in paying top dollar if you dont have to. mainly threw it out there for part number comparisons. (although they had a wrong number for my CR250 so double check)
    When you are all set, can I have that master cylinder?
    I wanna have a go at making it flow. Good training for me.
    OHHHhhhhhh..... Mrs. Duncanmoto will not be pleased with you my friend. You're in trouble....
    Jul 2008
    Marlborough Mass
    hahah sure I'll drop it off when I come by for the chain and sprockets!
    Maybe ill watch!
    Jul 2008
    Marlborough Mass
    well the master cylinder fits....the only issue I have with it is one of the screws holding the cover on is about to strip...FML...its one thing or another with this bike
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Heli Coil the bitch and forget about it
    Posted by Jane in BoxChat
    the head of the screw or the threads of the screw?
    if head, can you buy a new screw?
    if threads, can you use loctite?
    I have a tap kit you can borrow if you think it will help.
    Jul 2008
    Marlborough Mass
    eh fixed it, but im having the same luck with this one, good thing it was only 30$
    but now my old one seems to be working
    i swear this bike is going to drive me insane
  1. For Sale - Parts & Tools | Brembo GP Radial Master Cylinders
    Last Post: 12-05-16, 08:07 PM
  2. anyone have an xr250r?
    By gamorg02 in forum Dirty Bastards
    Last Post: 07-15-10, 02:10 PM
  3. Holy diesel lookin master cylinders
    Last Post: 10-30-09, 07:27 PM
  4. Replies: 3
    Last Post: 01-28-09, 06:43 PM
  5. Replies: 12
    Last Post: 09-04-08, 03:53 PM
