Page 4 of 4 FirstFirst 1234
Results 76 to 88 of 88
What have you done to your dirt bike today?
  1. #76
    Re: What have you done to your dirt bike today?
    Just cleaned the K&N in the bath tub. Thinking about putting the ice tires on rims just because I can. Not sure if I am actually going to use them this year.
    Lifer union's Avatar
    Blackstone, MA
    I looked at mine today and walked by it.
    James
  3. #78
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    Strapped on the spikes and went for a short ride. I broke in the clutch and finally got to ride with the LHRB on the new bike. It was good. There is tons of stick with the carbides, hopefully life works out and I can race JDay on Saturday.
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
  4. #79
    Built these:
  5. #80
    I took a swing at repairing the electrics on the new toy today. The headlight and tail light do not work. But the heated grips I wired up do. So I did something right and something wrong.
    One of the elements on the headlight bulb is broken and there is no marker light in the receptacle. I'm guessing the broken element is the low beam and the high beam is not wired on my machine. The headlamp on this thing has had the crap kicked out of it. The contacts on the bulb are filthy. Although that does not explain why the tail did not work.
    I romped around the back yard for a couple laps. I already think I really like this thing. Runs really well now that it is re-jetted. Quite a workout in the snow with unstudded, regular tires. But fun as hell. Lugs and chugs very nicely. Not terribly loud either.
    Clutch pull is a little stiffer than I expected. Midwest Mountain lever is due this week. Although I'm thinking I should flush and bleed the hydraulics on this thing sooner rather than later.
    Fairhaven, Ma
    Built these:
    Those look amazing! Nice work man! Is that a VE front? What did you use for the rear?
    LRRS EX 151 AMSOIL
  7. #82
    KTM wiring is crap, never could figure out why they wouldn't put sealed sockets and connections on a dirtbike. You are correct, the high beam is not wired, if I recall, it's the yellow wire and is not connected to anything. Is there a switch to turn them on and off?
    It's a vulcanduro, yes. Ve 33 or 35, I can't remembe rwhich. The rear is a irc mb5 or m5b...it's what lee said to get. It's also the same tire Kevin's had on display at the NETRA banquet, studded the same way. For $279 I think...which is more than I spent to build a set of rally's today.
  9. #84
    Bellingham MA
    Nice work Chippa! I hope Snowmageddon doesn't keep us from ripping on Saturday.
    The headlight bucket itself is filthy. All the contacts on it are really bad. Some sandpaper should clean it up. But I'll need a new bulb.
    Yellow wire comes from the stator I think. White bus has the regulator on it and is the +12VDC feed for everything. I think.
    Brown is definitely chassis ground. Grips are across the white and brown busses. (Actually, they are grounded separately.) But they work. Can't understand why the tail doesn't.
    Bike is fun enough for me to not give a damn for now though.
    How do you stud those tires? How are the studs mounted?
    I'm talking about the pig tail coming from the headlight assembly, not the main harness. If it's the factory style headlight assembly, there's a 3 wire pig tail coming out of the headlight, and only 2 wires feeding it from the main harness
    Each knob is drilled and then glued and each stud goes in with a gun. It's laborious.
    I think next season I'll build a set of long ones.
  13. #88
    Taking this to my absurdly long 2-stroke thread. Most probably don't give a damn.
  1. Wanted - Motorcycles | WTB: Kid's dirt bike gear and 50cc dirt bike
    By Piston in forum Wanted
    Last Post: 02-03-18, 02:22 PM
  2. For Sale - Parts & Tools | Dirt bike tires (dirt and studded)
    By CEO in forum For Sale
    Last Post: 09-10-15, 11:25 AM
  3. Anyone wanna ride dirt today?
    By JettaJayGLS in forum Dirty Bastards
    Last Post: 04-26-11, 05:39 AM
  4. picked up a dirt bike today
    By johnnym in forum Dirty Bastards
    Last Post: 05-03-10, 06:06 PM
  5. Rode today sort of dirt
    By theothersean in forum Dirty Bastards
    Last Post: 03-17-09, 06:47 AM
