Page 46 of 49 FirstFirst ... 6263637383940414243444546474849 LastLast
Results 1,126 to 1,150 of 1223
street legal 2-strokes
  1. #1126
    Re: street legal 2-strokes
    https://www.youtube.com/watch?v=mmoMeX8bRTk
    Check out the bikes they're fielding.
    DUDE
    THIS IS AWESOME! LOLOL
    “That bike is surprisingly good.”
    And I know exactly how the bike feels when the rear bounces all over the places and “it has no low end you gotta rev it to idle.”
    The 'rev it to idle' is the result of a worn clutch pushrod assembly. The rod, ball bearing and tophat eat each other over time, and eat into the pushrod. The fix I found was to reshim the assembly with valve shims in the top hat. Was pleased to see both bikes make it to the end.
    Also, becoming more and more of an AJ fan, just a good guy all around, looking forward to doing another school of his if the opportunity arises.
    where the clutch cable attaches is also a discontinued item
    I bought an extra used one from ebay just in case
    was also pleased to see both bikes finish...and AJ was indeed a good dude!
    that RMATV video was a 4 part series...check out the first few
  5. #1130
    Literally just finished the first three. Can you imagine if we had known and both showed up with our machines at the beginning.
    street legal 2-strokes-yz250-logic-png
    people are particularly more impatient this holiday season
    690 is still in the shop, so I took the YZ to sneak away a couple hours to get my sanity back
    of course the closest OHV area is closed from the recent rains
    oh well; I just rode the fire road next to it
    but man...every first ride makes it feel sooooooo fast
    and the weirdest thing - the stutter at WOT/higher RPM's wasn't there
    I didn't change a thing. The bike's been sitting for a month covered in dust...it started 4th/5th kick and it rips.
    Maybe because it's a little cooler and I was riding it close to sea level?
    i dunno
    snuck in a little bit of this
    amped me up to plan the next day to ride
    now if I could only get days off...been working 8 or 10 days straight...and now people are testing positive for covid, and I'm being picked up for a corporate project. yay.
  8. #1133
    ahh the Cajon pass
    the gateway to the high desert
    being along the freeway reminds me of riding at Franklin along the highway
    rode the trails and hills near the freeweay
    and it just rained, so epic chocolate cake conditions
    you could be WOT just sliding through these mushy conditions
    bike ran great! It was loving 48-55 degrees out...coolant temps were under 150.
    it's just such a fun light trail bike after riding the 690...I definitely want to transition it to full time small bike duty
    it still has that studder/miss...definitely gonna try some main jet changes
    my only major issue is SoCal traffic. It took me 2 hours to get to the staging area, and I only rode 2-3 hours...then 1hr6min drive home. If it was only an hour drive; yeah it's a good fix. But a 2 hour drive was a little tedious for a short small bike ride.
  9. #1134
    first ride in almost 3 weeks for the YZ
    she fired up in 4-5 kicks
    took her where I took the 690 last time
    the YZ is obviously way more fun in the tighter stuff!
    we found some flowy single track stuff in the hills
    the spot wasn't bad; staging area/CVS parking lot was only 27 mins from home, but you have to ride 5 miles of pavement to hit the dirt. I kinda like that because it keeps a lot of quads/dirt bikers out of the area since they don't have a place to park. Rolling hills with single track cut into it...you have to connect some of it with some fire roads, but it's not too much fire road.
  10. #1135
    short sections, but flowy
    22 miles, done in under 90 mins
    time-lapse mode: 1 pic every 5 seconds.
    May even try 1 pic every 30 seconds & turn off the LCD.
    2 batteries should run a full day of set-it-and-forget-it
    I also splurged and got the flywheel weight!!
    I am about ready to pull the cylinder head off and do an inspection, so I may add the FWW at that time.
  11. #1136
    man, that looks dreamy
    I try to tear down & inspect when I can:
    cooling system is doing great...almost full
    head still looks clean AsF
    I never want to run a higher compression head ever
    no detonation/hot spots...no snags on cylinder stripes:
    I am suspicious of this power valve stopper
    ordering a new one now for insurance
    EDIT: they're $100 each brand new!
    I also tried packing my tools and test fitting the tail pack:
    umm...no...
    even if I move the plate and tail light back, that's not a good idea
    it's attaching to just fender plastic. No subframe. It's heavy and may rip off the whole fender in the whoops.
    rotating it *may* help, but I dunno...
    I'd also need to fab special brackets to line up holes.
    otherwise, about 4 spokes were loose on the rear wheel
    filter just spray cleaned & rinsed w' water and looked pretty good
    oiled her up and good to go
    put on the flywheel weight.
    on pavement, it feels about the same.
    can't wait to try it on the trails!
    but if it doesn't make a noticeable improvement, I may take it off...one less thing to wiggle loose and fail.
  13. #1138
    tested out the flywheel weight today:
    honestly, it's kinda meh
    the rpm's hang a little more than usual, and maybe you can lug it 5% more than usual before it stalls, but it's not too different than without it.
    It was a wee bit more steady in the ST; but the most benefit simply comes from your own rider skills in balancing and managing the throttle
    got to see some snow up there too:
    ocean views
    And I witnessed a helicopter landing:
    not gonna lie, it was pretty bad ass!
    he was meeting his son up there
    gonna tighten down the flywheel weight, do another run in some hills or desert, then decide if I want to keep it on
    getting the ported cylinder repaired w' a cylinder head milled out for pump gas is where I'm thinking I want to try next in the motor.
  14. #1139
    interesting about FWW, maybe give it some time. they really only shine in the slower tech sections when a little more momentum in the motor will keep it alive. i found that nice in the woods when adding to an MX bike.
    Bear in mind that gen YZ doesn't have a small flywheel to begin with, so adding a weight isn't the massive change you get compared to some starting with tiny flywheels.
    ocean views
    That's an MD500 NOTAR ("NO TAil ROtor"). Instead of a traditional tail rotor, it routes exhaust from the turbine to provide anti-torque thrust. They're very cool.
  17. #1142
    ah, got it, that makes sense then.
    I may have dropped things too early in the past
    I will definitely keep it a little longer to give it a chance...I didn't know it was already heavy, credit to Kurlon!
    if you can stand staring at my handlebars for 30 seconds, this is how it did:
    my palms get sweaty just watching it...sketchy narrow sections
    but honestly this 1st gear ish kinda looks like the ideal spot to use a FWW...maybe I should keep it
    VERY COOL! much thanks
  19. #1144
    tried some more seat time on the FWW
    it definitely makes the engine speed a little more stable
    found some "new to me" ST sections in the local ride
    they're only 30-60 seconds of riding, but something to add onto the usual ride...not too technical
  20. #1145
    flywheel weight cover spacer has uneven "squishiness" which doesn't allow for even pressure from the case screws...and despite tightening it came loose.after 3 rides
    bolt got stuck on the shifter
    spacer slid down and dragged/jammed the flywheel so engine wouldn't turn over (felt like it was seized)
    I had the tools to loosen everything, line up the spacer, and get going, but mannnnn....stock yamaha is best! when you add mods, it's just another thing that can break.
    after that was sorted, I did the loop...seeing some yellow:
    looping some of the ST together, it's a 25-30 min loop
    honestly, that's an excellent mid week rip...I wish it was closer than 35 mins away!
    FWW is coming off, ported cylinder going to EG w' head to mill for pump gas. May try a lectron or PWK38 AS next.
  21. #1146
    Haverhill, MA
    I wish I had any "legal" riding within 35 miles of me that was worth riding on. Closest thing to where I live is the Rockingham Rail Trail which while it is nice to have a trail that is open year round the fact that it is flat, relatively straight and has a very low speed limit that is enforced makes it not so appealing to ride there. Other than that to be legal I have roughly an hour ride.
    There are some not legal areas that are somewhat tolerated but if the F&G or DHR show up it can get expensive quickly
    woes of the dirtbike riders in 2022...unfortunately this doesn't get any easier
    blows my mind that riding a dirt bike in a hilly area that with nobody else around you and they'll send a helicopter, 2 police cruisers, and a tow truck.
    I'm looking for a plot of no-mans-land within 15-20 mins away that nobody else wants; something hilly with no water, power, or even anything paved LOL. If it's a cheap enough cash buy, I'd hit it. Ride out (no freeway), do some laps, come home. In the mean time 30-120 min drives will have to do...1st world problems
    meanwhile, thank you auto-search on eBay!
    here's my next mod...
  23. #1148
    daylight savings mean after 7pm sunsets
    the new-to-me spot is ~35 min drive from work on toll roads.
    if I'm loaded as I get off work, I can KSU 6-ish and get in a 1 hour ride on the single track-ish loop.
    some people on groups are bugging me to check out another spot 1 hour away near Lake Elsinore.
    Hoping to check out 2-3 more epic spots before the summer heat turns on!
    low beam doesn't work...guessing the baja designs resistor burned out...gonna order a new harness & just run high beam for now
    clutch slack was high too...adding it to the routine checks.
  24. #1149
    another post work 1hr quickie loop
    there was a critical uphill moment that FWW ROCKED! I was gonna stall and the RPM's just kinda "hanged" so it stayed running! I kinda wanna keep it now...I'm wondering if I can run the cover without the spacer
    I also finally need to replace my rear tire. I can usually slide the rear out on fire roads no prob; but this time I couldn't save it and had a gentle dirt nap. Going to an 18" + nitromoussse
    I also got the FMF Gnarly - it's in pretty good shape for its age! not all rusted out
    next steps:
    -18" rear wheel, new tire, nitro mousse
    -FMF Gnarly + jetting
    -PWK38 AS
    -mail ported cylinder + head (for cutting) to EG
    ^ ultimate trail combo!!!
  25. #1150
    fun fact: an 18" rim doesn't necessarily mean the (rim+tire) is any shorter than a 19" setup
    18" is on the right
    just threw on a cheapo DOT Kenda trackmaster. For "C" ride duty, cheap = best.
    Wiggles funny on pavement, but hooks up *enough* on dirt
    the 19" and 18" even have the same 49 tooth sprocket = straightforward wheel changes
    1st ride w' out the flywheel weight:
    Definitely stalled accidentally a couple times, but the trade off for a quicker revving motor (and stator cover properly secured) is worth it.
    ST is a little overgrown
    found a little bit of new stuff too, and honestly adding a couple more ST sections makes the loop *just* entertaining enough for a 2-ish hour ride
    after doing 2 days of canyons w' Iglu, getting back on dirt with the YZ felt like being on a rocket ship
    dirt is so fun
  1. Street legal ktm 250mxc
    By 05RC51 in forum For Sale
    Last Post: 05-25-13, 09:12 PM
  2. Street legal dirties
    By Chippertheripper in forum Dirty Bastards
    Last Post: 10-15-10, 04:18 PM
  3. Street legal ATVs
    Last Post: 07-04-09, 10:07 PM
  4. KTM 200 EXC Street Legal
    By improvedfd in forum For Sale
    Last Post: 04-01-09, 05:47 PM
  5. R1 close to Street Legal!
    Last Post: 07-05-04, 05:34 PM
