Page 2 of 2 FirstFirst 12
Results 26 to 31 of 31
Lean Angle and Contact Patch
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    Re: Lean Angle and Contact Patch
    You are the tire expert, Dave. I will always defer to your knowledge of the engineering details. I was just wanting to deflate the old myth that the contact patch changes significantly enough for it to matter to the average rider.
    Its the loading of the radial tire that is increasing the contact patch, which is an obvious statement. more pressure on the tire, more of it will be touching the pavement.
    Quote Originally Posted by Ken C View Post
    So, the reason to hang off is to: 1.keep hard parts from dragging 2. keep the bike upright so that you keep the contact area as far away from the edge as possible to prevent "running off the edge" 3. reduce the drag that occurs when you ask the tires to roll on the smaller outside part of the tire 4. to use body weight to influence control.
    To add to this list, keeping the bike as upright as possible also allows the suspension absorb bumps in the road better.
    Sep 2001
    Western MA
    Yep. Good addition.
    I wonder if one can really "run off the edge" of a tire? I think most people can drag parts before running off the edge. My 125 had massive clearance and I still couldn't run off the edge.
    Sep 2001
    Western MA
    Even the above average rider will never run out of tire on the street. And only the faster track guys even have a chance of doing it.
  1. Think you got lean angle?
    Last Post: 04-11-13, 02:05 PM
  2. GPS logger with lean angle
    By Marc R in forum General Track Day Talk
    Last Post: 03-08-13, 05:12 PM
  3. Lean Angle
    Last Post: 09-10-09, 10:52 PM
  4. Lean Angle 10/2 Trip
    By Vix in forum Rides & Events
    Last Post: 10-07-08, 12:40 PM
