Results 1 to 13 of 13
01 Ninja doesn't want to down shift...
    Try to not be offended DocCola's Avatar
    Everywhere, USA
    this just started in the last 50-60 miles of riding, done today. NEVER had a problem with my bike like this til now and I've put over 11,000 miles on it myself.
    So the issue is the bike started not wanting to be down shifted from 2nd to 1st when coming to a stop. I would have to kick the shifter kind of hard to get it into 1st and it would go. Then it started to get harder and harder to get into 1st. Now I have to really fight it to get it into 1st. Hell, in the last couple miles on the way home after getting off the highway down shifting through the gears it gave me a hard time getting into 2nd or 3rd.
    So it's pretty annoying. I'm not sure what it could be, linkage, trans, clutch???? I have no idea. The bike will up shift no problem at all and down shifting through the higher gears is fine...but now it feels like it's getting worse.
    Any ideas what I should look for? Suppose to be going for a ride tomorrow, don't want to lose out on a beautiful day not being able to ride. Even though I'm not incredibly mechanically inclined but I have basic knowledge and I have my father to help me who knows his stuff mechanically...just looking for ideas of what it could be or what to look for.
    Ajay
    My Facebook-add me
    "The things in life you regret are the risks you never took"
    ....There is nothing but love and tent pitching at the BoMo days....
    KB KB's Avatar
    Manchester NH
    Re: 01 Ninja doesn't want to down shift...
    Adjust the clutch cable.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Member gjarrett29's Avatar
    concord NH
    I would like to know to my 636 started doing the samething it comes and goes
    Sep 2007
    Hinsdale, nh
    It could be a couple of things,
    1-- it could be a bent shiftting fork on the worst end or,
    2-- it could be the detent spring , does the shift lever seem to have spring tension in both directions? or,
    3- I have had problems in the past with some oils, I had a bike that I ran Spectro oil in from the day it was new and I sent it out to a shop for some repair and had them change the oil and they put Torco 10-40 in it and after about 20 miles it started hanging in gear, dumped oil and put specto back in Problem solved hope this helps
    4- Adjust the clutch
    many a biker have been ruined by a wife and a full time job
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    Oil would be my first inspection.
    When did you last change it?
    Is the level correct (ie. Not overfilled)
    Did you switch oils recently?
    Chaing the oil now and look for metal on you drain plug or in the oil.
    Lifer union's Avatar
    Blackstone, MA
    Make sure the linkage is tight. That would be my first place to look.
    James
    Besides the aformentioned, try blipping the trottle when you downshift - keep the RPM's up. And yeah, I said 'trottle'...
    Lifer Punjistick's Avatar
    Norwell, MA
    Does a Ninja use a shift drum? I had to replace that in my EX-500 when it woudn't downshift. But mine did it in all gears not just getting it into 1st.
    Everywhere, USA
    Well to update you guys it's still doing it and now its acting weird for each gear, well most but I think its linkage related because I realized if I'm going to down shift I have to push the shifter up a bit with my toe then down shift. Works fine. A bit annoying but I can go through the gears now up or down without to much hassell. Guess its time to call a few shops since I don't have the time, tools or knowlage to do it myself. Thanks for the input.
    Ajay
    My Facebook-add me
    Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    Quote Originally Posted by KB
    Bingo!! Unless you have a hydraulic clutch, in which case bleed it, unless you have a Ducati in which case throw out the cvrappy stock slave cylinder and buy a nice one from yoyodyne.
    Raymond NH
    My 01 Ninja did something similar and it was just a matter of cleaning up and re-greasing the pivot point of the shifter. It should have a grease fitting, IMO.
    concord NH
    I did try a new oil thats when it started went back to old brand hasn't do it again yet
    Some transmissions are very particular with their oils.
  1. Replies: 5
    Last Post: 04-25-14, 10:43 PM
  2. It doesn't fit but...
    By SEVENSGT in forum General Bike Related
    Last Post: 11-27-03, 02:31 PM
