Results 1 to 25 of 34
ok, what the fuck is a "throttle body" and why should i care about how big it is?
    NESR ruined my life. chr|s sedition's Avatar
    Aug 2004
    I ride...someone else's bike.
    see subject line.
    educate me,
    -sedition
    "Up front there ought to be a man in black." -John Cash
    LISTEN TO SLAYER
    If I get another fuckin' bike stolen...
    It's the fuel injection version of a carburettor, and the bigger it is, the more fuel flows through it and the faster the bike goes.
    Atlanta, GA
    The throttle body is the mechanism where air comes in from the air filter and into the intake manifold.
    In an TBI, or throttle body injection setup, the throttle body functions like a carb, as the fuel injectors sit in throttle body, and the air/fuel mix is sent into the manifold.
    Today virtually all manufactuers (of cars and bikes) use "port" fuel injection, otherwise called EFI. Air is routed into the intake manifold, where it is mixed with gas via fuel injectors. The atomized mixture is then routed into the combustion chamber to be burned.
    Bigger is not better with throttle bodies. They have to be matched according to several factors, including: fuel injector size, pressure regulator & fuel pump rates, intake port length & size, cam size & timing, ignition timing, exhaust flow, head port flow, etc. etc. etc.
    All parts of the fuel system should be matched to yeild a stoichiometric (fancy word for 'ideal') air:fuel ratio. For gas engines, the ratio is 14.6 parts air to 1 part gas. This condition will lead the fuel and o2 to be completely consumed, resulting in more efficiency, power and reduced emissions.
    In my exerience it's generally best to use a proven combination of parts, usually selected by the manufacturer, aftermarket tuner, or otherwise "wicked smaht" person.
    Andrew
    03 Suzuki SV650
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    BINGO:
    Motor is a air pump.
    More air in means more power out........
    Its like breathing through a straw. The bigger the more air you get.
    -Suf Daddy
    Suf Daddy.
    Just Registered
    Mar 2003
    Shrewsbury, MA
    Well said. Kudos!
    Winchester, MA
    You, sir, are no fish
    Aug 2004
    in this case, that person would be you. thanks for ed-u-ma-cating me.
    -chr|s sedition
    LISTEN TO SLAYER
    ancosta: could you be a bit more specific???
    Good descript!!!
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    E lectronic F uel I njection
    Nozzles at each cylinder are
    Multi port fuel injection
    Seperate nozzles just above intakes so no gas wetted down the inside of a manifold so computer give tree hugger gas amount at each firing not the 12 to 1 for max power.
    Also you always want the air after leaving the air cleaner to stay moving with inertia so that the thottle bodies one you control and one the computer controls open at a rate the engine can inhale so no "bog"
    Glen Beck is John the Baptist
    Atlanta, GA
    Good descript!!!
    Sorry got a little rainman with my answer. One of my biggest character defects
    Andrew
    03 Suzuki SV650
    Not at all! it would be a flaw I had asked you if you wanted a drink and replied with something that in depth...
    YES, almost all vehicles have EFI (Electronic Fuel INjection) but I'm not sure about the rest of your statement
    some vehicles have multi-port fuel injection, some have throttle body injection
    on my bimmer I have individual injectors for each cylinder (multi-port) on my winter bomb chevy, it's one injector in a throttle body
    Atlanta, GA
    I thought that it rolled off in the early 90's. Maybe some of the pushrod motors still used it later than that? I think it would be tough to find a OHC motor using TBI, but that is more of a guess.
    Andrew
    03 Suzuki SV650
    It doesn't matter what type of injection system or carburator it has, it still has a throttle body
    Atlanta, GA
    http://auto.howstuffworks.com/fuel-injection.htm
    They 'splain it better than I can
    Andrew
    03 Suzuki SV650
    Lifer GMAN226's Avatar
    Coventry RI
    Originally posted by Degsy
    carburettor
    You spelled that wrong .. Damn Brits
    G-man
    Gerard
    there's nothing called a throttle body on my old Vanagon or bimmer.... air flow meter? the injectors go right into the head... both have antiquated Bosch K jetronic
    What's your throttle cable hooked to??
    Aug 2004
    Baltic,CT
    Your metamorph catapiller is residing in your manifolds throttle body
    the air flow meter
    Oct 2001
    Bedford, MA
    I think with bikes maybe they are using the terms different?
    The throttle body is the housing with the throttle butterfly in it right? It opens with throttle input to allow more air in? Same place where the mass air meter is in a car, but the bike is missing the air flow sensor?
    You sir, are correct You can call it a air meter, air valve, throttle boby or whatever other fancy term each manufacturer wants to call it.
    BTW, my bike has a twist grip on it and not a twist throttle
    But my point is I DON"T have throttlebody injection,
    I know you don't, you told us that a few posts up
    But it does have a thottle body
    If you want to call it that, but if you go to a parts store looking for one you won't get one,
  1. For Sale - Gear | Bell Qualifier (L) "Devil May Care"
    By Yev in forum For Sale
    Last Post: 06-23-16, 01:32 PM
  2. "Twist the Throttle"... online TV series. Pretty interesting.
    Last Post: 03-17-08, 01:33 PM
  3. "Who the fuck highsides an EX500?"
    Last Post: 09-25-06, 12:15 PM
  4. Tues, 5/10, First Annual "Fuck Weekend Rain Ride".
    By chr|s sedition in forum Rides & Events
    Last Post: 05-11-05, 10:28 AM
