Page 1 of 3 123 LastLast
Results 1 to 25 of 62
2001 Suzuki GSX1300R Hayabusa - breakdirt916
    stretch swingarm, turbo, nos, night drag racing brah
    51k ish miles, chain "2k ago" (meaning maybe 10k ago?), "tires 60%" (meaning tires 30%), plastics came silver and painted blue....mechanic owned, but was as honest as a mechanic could be with me
    top case, some touring, some commuting, sell it in the spring
    another occasion that winch assisted motorcycle loading was worth the investment
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Re: 2001 Suzuki GSX1300R Hayabusa - breakdirt916
    Turbo Hayabusa , what a score …..
    We will have to get all the Busa guys together for a ride.
    Like to see how my 1441 holds up to it .
    Attached Thumbnails Attached Thumbnails 2001 Suzuki GSX1300R Hayabusa - breakdirt916-img_3422-jpg
    TIMMYDUCK
    He was being sarcastic Timmy...
    And he's in Cali...
    Cool bike bhavesh!
    Hoe Lee fucking paint job.
    It was so piggy, that even out of a 2wd truck with a “ladder” type ramp (readyramp), as the back tire was on the ground the front tire was sliding down locked. Front brake was not enough to slow it down. Be careful unloading this beast
    Quick spin down the street under 6k, oops 60mph
    So far it looks like a flip bike for me. Maybe 4-6 months and sell.
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    Time to start living your life a quarter mile at a time...
    if I intend to do any commutes/grocery runs on it, I absolutely need a top case for the jacket/helmet
    terrified of the cost having used a Givi product on the Vstrom, google shows that other busa users have successfully speed test china stuff
    Amazon.com: Comie Motorcycle Tour Tail Box Scooter Trunk Luggage Top Lock Storage Carrier Case w/Soft backrest&Handle - 48L Capacity - Can Store Two (2) Helmet (Black): Automotive
    for $53 shipped, it's worth trying and throwing out after 6 months
    SW mototech makes a mount under the rear seat, or I could just bolt the mounting plate to a junk stock rear seat (found one on CL) then put the bubble cowl back on when I sell it
    May not be a bad idea to buy a Givi top case, then all you'll have to do is buy a different mount for your next steed. Congrats, you're now like Wile E. Coyote on an Acme rocket.
    Lifer Falko's Avatar
    MoonTown
    Congrats on the official NESR starter bike.
    FI light came on...stopped by the local mechanic and he said it's likely the aftermarket exhaust...google shows there is a connector you an bridge with a wire to see codes
    so the bike was -1/+2 re-geared so the speedo is off by roughly 15%....but still, I short shifted until 3rd then got on it, and oops 115mph indicated
    the thing about this bike is that 97mph felt like 40 on the FZR...it's deceptively fast...so even if you are gently rolling on at 5krpm you are suddenly going faster than you expected. When you are really getting on it in the upper rpm range to feel the rush, then you are playing in the triple digit speeds real quick
    as expected with any big bike, mid range/cruising torque is more than adequate, so cruising in top gear, rolling on is very comfortable....excellent cruising bike...but definitely better above 40-50mph
    Shifter is too high - easy to upshift but felt like I had to lift my leg to downshift
    Apr 2004
    boston burbs....
    and the chicks.... are you beating them off with a stick yet?
    hmmmm......
    Feb 2003
    Yes , put her into dealer mode and join Hayabusa.org
    Full service manual and code read out is at the site , plus the world most knowledgeable Busa guys .
    And since we are guessing what's wrong .
    I say the code is a weak fuel system from the pump being old and the filter being gummed up.
    TIMMYDUCK
    Feb 2003
    Every guy with a Busa has to beat the ladies off with sticks .
    TIMMYDUCK
    The $53 top case case came in - obviously a little more flimsy than a Givi as expected, in terms of construction plastic and hinges...but from the initial feel, it looks more than adequate for what I am using it for
    it does fit 2 helmets as advertised, but the interior shape is a *little* off so you gotta twist things around for a snug/tight fit
    gotta toss that dusty 2nd helmet
    one of the local Long Beach neighbors came over telling me not to add it since it takes away from the appeal/cosmetics/look of the bike. he said get a bacpack...he also told me he could handle it and wanted to ride it. sorry brah....not a busa.
    my needs: will it fit a helmet, jacket, and knee guards if I rode somewhere?
    yes
    from what I've read on the forums, the busa is not a bike that has a variety of inexpensive luggage options. This ain't no Vstrom. As a result owners have periodically found ways to adapt their own - cheapest way is this $53 case, with the rack bolted to a used $30 passenger seat. Next step is $237 rack to hold said case...then the cost doubles and triples if you want bike specific parts, name brand cases, saddle bags, and paint matched equipment. I know a top case bolted to a old seat is ugly, but I am using it for commuting, grocery runs, touring, and will take all of it off in the spring when I sell it. Maybe add some heated grips, remove/store the lower fairings, and add an LED auxiliary lighting kit with the flashing brake lights and extra marker running lights to provide extra safety visibility for the "is that a car with a headlight out?" appearance of most motorcycles. Bike already has a yosh pipe (which is honestly pretty mellow) so hopefully it saves lives.
    fyi the red on the top case are not lights. they are not even reflectors...just red lenses maybe I can mount an aux brake/tail light there
    Edit: dropped the shifter one notch lower and it is way easier to shift and more comfortable on the knees. Finally finding my central balance point and getting weight off my wrists.
    Feb 2003
    Nice rocked 200 Foliage miles on the Dragon bike today.
    Attached Thumbnails Attached Thumbnails 2001 Suzuki GSX1300R Hayabusa - breakdirt916-img_3544-jpg   2001 Suzuki GSX1300R Hayabusa - breakdirt916-img_3519-jpg
    TIMMYDUCK
    Fixed
    Beautiful...this is what I want to do...touring!
    Feb 2003
    Oh, Boy .
    You can load your girl and still break 175 on the speedo .
    Attached Thumbnails Attached Thumbnails 2001 Suzuki GSX1300R Hayabusa - breakdirt916-img_2776-jpg
    TIMMYDUCK
    Feb 2003
    Fixed
    No, it is not ….
    Are you single ?
    Have you consistently owed a Busa 2001 ?
    TIMMYDUCK
    Mar 2007
    Andover, Ma
    Oh, Boy .
    Needs a bigger cooler...
    Did my first commute and tried some freeway rolls...it will definitely get you there quickly.
    The crazy part is it is so damned stable on the way you don’t feel like you are going the speed you are...silky smooth and solid
    What that means to me is that it’s easy to override your braking safety bubble. Especially with lane splitting you really just need to slow down and be prepared to stop at any time. So I still have been riding like a cop is behind me. The good news is this bike cruises quite comfortably in top gear, and still has power to pass without shifting. Never looked for 7th gear. Torque rules. I still need a top case...ran over to a unit to grab rent and mail and couldn’t fit it all under the cowl. I also went to dinner with friends and hated holding a helmet and wearing a jacket The whole time.
    Found a Bazzaz quick shift unit under the seat
    First gas up 30.4mpg
    Feb 2003
    Quote Originally Posted by klp View Post
    A cooler loaded that size is just right ……
    Otherwise you are in a constant wheelie.
    TIMMYDUCK
    Is it really turbocharged?
    Naw...thought I would get the stereotypes out of the way early
    She gets a little hot in stop and go traffic when it’s 80 out
    I am consciously not running any yellow lights...keeping a braking bubble like I am riding in snow, lots of space and off the gas early
    And the bike cuts out a wee bit off the line...solved with more throttle...maybe that’s what the FI light is flashing for. Hopefully getting a chance to check codes this weekend
    Does not fall into turns like the Weestrom...May be tires as the front pushed a little on my favorite exit ramp. Best get fresh tires before a canyon run. Tire pressure was high 20’’s and I aired to 40 per the frame stamp
    Edit: sad day in the OC...3 moto fatalities this AM during commuting...a cager swerved into the HOV lane and put a biker into the median, bounced back then hit by a Jetta. 2nd guy rear ended a truck that was trying to redirect traffic. Separately a guy rear ended a semi then got run over by a car. Be safe out there fellas
    Edit 2: with 40psi it returned an adequate 35.9mpg...this ain’t no Prius and that’s pretty good
    Haverhill, MA
    I would bet that it stops better than you think it would. I do understand giving it a little bit of respect though. Fast, powerful, not so light (lighter than a lot of bikes in its class though) bike that is new to you.
  1. 2007 Suzuki Vstrom 650 - breakdirt916
    Last Post: 08-25-19, 01:56 PM
  2. For Sale - Motorcycles | 2012 Suzuki GSX1300R Hayabusa
    By MFChop in forum For Sale
    Last Post: 03-21-19, 10:12 PM
  3. For Sale - Motorcycles | 2001 Suzuki SV650
    By sveesix in forum For Sale
    Last Post: 03-10-14, 08:49 PM
  4. 2002 Suzuki Hayabusa
    By v2winstunter in forum For Sale
    Last Post: 05-07-11, 07:36 PM
  5. 2005 Suzuki GSX1300RK5 Hayabusa
    By TIMMYDUCK in forum For Sale
    Last Post: 11-15-07, 09:00 AM
