Results 1 to 25 of 30
Astars boot questions
    Branford CT
    Well I just got my new Supertech R's in white. I like them so far but I got a few questions for thoes with A* boots or thoes who have the R's. Do these run big? I wear a size 11 in Dainese boots, I got a size 45 (10.5) A* boot and while it fits well, my toes dont touch the tip of the inner bootie. There is maybe less than half an inch from touching. Not sure if thats too big. The next size down is a 9.5 might be too small.
    Also, is it just me or are these boots thick? As in trying to fit my foot under the shifter of my bike. I did a test fit on my bike with it on the rear stand and it felt tight. is this normal for A* boots? Something I have to get used too?
    other than that I like them. Very comfy!
    #277
    Re: Astars boot questions
    It's not something you should have to get used to, just adjust the shift lever to fit your new boots
    I've never has A* road boots before, but have had plenty of tech series offroad boots and always seem to have to adjust the shift lever to the boots
    Branford CT
    I dont have rearsets. I got the stock stuff for now
    #277
    You should be able to raise and lower the hight of your shift lever even if it's stock?
    Banned G21forme's Avatar
    Lakes
    There's no adjustment in the gear selector? I will say my sidis are super tight for the track while my A*'s are a bit looser for the street but I've never noticed a difference in shifting. Granted my bike is GP shift and I know it tech shouldn't matter but I think it makes a little difference.
    I take a 11-11.5 in Adidas shoes and my A-stars fit like a glove and are size 45 euro (10.5 US). And I have never had a shifting problem with them. But I also have the SVX model.
    Branford CT
    I might be able to adjust the stock shifter. I never thought I could, I will look into that.
    #277
    A*s run big. I wear a 10-10.5 but my boots are 9.5
    The bar that runs from the shift lever to the motor has a locknut on each end (10mm?). Break those loose and spin the bar and it should move the lever up or down. Sit on bike with boots on and check, don't forget full tuck too. Then retighten the lock nuts.
    Could you also loosen and spin the piece that slides onto the shift shaft?
    Ya, I guess you could do that first. Go a couple teeth and then fine tune it with the rod.
    Branford CT
    Well before I do that, Do these boots break in? As like flatter on the toe shifter pad? I am sure it will take time to get use to new boots. I had my Dianese's for 4 years
    #277
    Yes they will break in but you will still have to move it.
    You will also want to look at lowering the rear brake pedal. especially if ride in sneakers like I do.
    That's how my first high side happened.
    Jan 2009
    Middletown, Ct.
    Seems about how mine fit, maybe a 1/4 of an inch of actual space in front of my toes. I'd be shocked if you actually had a 1/2 inch. That's about a full shoe size. Talking to your wife I know you like to exaggerate size so I doubt there is anything to worry about Fit them like hockey skates, as long as your heal isn't coming up when you walk, you'll be fine.
    Yes sir, They'll feel like slippers in no time. Remember they aren't meant to walk around in.
    Only thing I changed in mine are footbeds. I got used to these playing hockey and love them. Little better walking around yet still firm to give you feedback from the pegs.
    http://www.hockeymonkey.com/shockdr-...PRODUCT_SEARCH
    Do you still need me to call you? I've been retardedly busy the last few days.
    Branford CT
    Quote Originally Posted by drinkingmymilk View Post
    Nice one on the size comment. No need to call I was just worried that these boots wont fit with my stock rearsets. My dainese boots were really narrow between the peg and shifter. I guess there is a learning curve with new boots.
    #277
    Lifer snwbrdr435's Avatar
    Middle of Nowhere
    If your foot slides around a little throw a dr scholls footbed on top of the one that is already in there.
    Lifer rbrais's Avatar
    Brooklyn, CT
    A* off road boots have a lot of armor in the toe area. Took me a long time to get used to it because I could no longer feel the shifter. Sounds like the road series are the same way.
    Branford CT
    Quote Originally Posted by rbrais View Post
    This is exactly it. My old boots were soft on the toe. These feel like steel toe
    #277
    Branford CT
    So do you all think I should adjust the shifter up or down? I will try it both ways just asking what everyonea experence has been.
    #277
    Lakes
    I have rear sets that you can adjust EVERYTHING so I've played with them a bit and it sounds like you need to move it up.
    Branford CT
    I have the stock crap, rear sets on next on my to get list. So you think move the shifter up? Thats what I was thinking as well.
    #277
    Lakes
    If you are having to bend your ankle/foot down so much just to get your toes under the shifter then yeah bring it up.
    Branford CT
    Sounds good thanks alot!
    #277
    Jan 2009
    Middletown, Ct.
    If you can't fit your toes under there isn't the only option up?
    And they work fantastic when you go down in them. Turn 1 and 3 at NJMP and 1 deer on deerfield ave (holy shit, never made that connection.) mine are fine and I've never had a foot/ankle problem.
    Branford CT
    I did not know you hit a deer lol!
    #277
  1. For Sale - Gear | Astars GP Rep One piece
    By peterz85 in forum For Sale
    Last Post: 03-28-15, 02:09 PM
  2. AStars Tech 2 boots
    Last Post: 05-20-12, 09:33 PM
  3. NewEnough Sale on AStars SG-1 Leathers
    By schleppy in forum General Bike Related
    Last Post: 01-11-09, 11:34 PM
  4. FS AStars Leather Pants and Jacket
    By Josephd14 in forum For Sale
    Last Post: 11-23-08, 05:04 PM
  5. Astars leathers
    Last Post: 02-04-06, 01:14 PM
