I Plan on putting my R6 in this weekend to get serviced, right now the bike has 15,000 miles and I was wondering what I should tell them to check out or get replaced. Any suggestions would be helpful. Thanks in advance.
-Spence
aw shit, thanks for reminding me i need my valve clearance checked![]()
Valves, Plugs, Oil, Coolant flush, chain & sprockets, ummmmm.... What year is it? carbs or injectors? a carb synch may be in order
damn, where's my owners manual? There's a section that lists everything that should be checked & at what interval. and there's alot of stuff (mostly just little visual checks)
are we looking for waldo or somethin?Originally posted by OreoGaborio
WHAT THE FUCK JUST HAPPENED?!?!?!?!? SEVEN RE-POSTS?????
looks like i got some deleting to do... I got it, D
Change the oil+filter and sync the carbs and you're doneFirst valve check on the R6 is at 26k miles so don't bother
I would say greese the wheel bearings but i'm sure every does that whenever they install new rubbers anyways so that should be all set as well![]()
trade it in for a kaw or zuk get rid of the yamajunkOriginally posted by DaSpence
-Spence
www.bostonmoto.com
Forum Rules
if you ask them to check that, then according to them you're going to need, a valve adjustment, with expensive shims, new plugs, synthetic motorcycle oil, colant flush, new chain, set of sprockets, and ummm....a flux capacitor and new difribulator modules.Originally posted by OreoGaborio
just rev it really high, kick her a few times and throw in water instead of coolant. that should take care of all your problems
Bras cause cancer.
Spence do it all your self, Change the plugs, synch the carbs swap out the anitifreeze., like R7 said next wheel change lube the bearings.
Thats all she needs...
Bikeless
I swear I was expecting a dirty post... but apparently, we're just talking about DaSpence getting serviced.... my bad...
GO TO TONY'S TRACK DAYS!
I'm Bikeless.
