Results 1 to 25 of 25
Bar end removal
    Littering and........
    Jul 2004
    Vermont
    Bar end removal
    Have I mentioned lately that I really suck at working on motorcycles?
    I bought my R1 with 1 stock bar end and one anti-vibration one. I am trying to install the anti-vibration one on the other side to make a matched set, but I can figure out how to remove in innards of the clip-on so I can install it. Here's some pics:
    Anybody?
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    Bar end removal
    TORCH IT!
    Brent LRRS #772
    2006 KTM 560 SMR
    I'm Sorry, What? Jank's Avatar
    Apr 2002
    North Walpole, NH
    Bar end removal
    Lefty Loosy??
    Chris J.
    squidtastic cyberxen's Avatar
    Oct 2001
    Massachusetts
    Bar end removal
    Does that alan head actually turn, or is it siezed (sp?)?
    No, Donny, these men are nihilists. There's nothing to be afraid of.
    - Mike
    CBR 1000 RR
    CBR 600 F4
    Pepperell, MA
    Bar end removal
    Did you seriously just ask that? Man oh Man.. If anyones that dumb they need to be taken outside and shot !
    www.tailofthedragon.com
    Mar 2002
    Amherst, NH
    Bar end removal
    seriously... torch it!!!
    with the aid of an impact wrench and heat that thing will come right out@@@
    Brent LRRS #772
    2006 KTM 560 SMR
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    fire wrench
    is the only way bro
    www.bostonmoto.com
    Forum Rules
    Lifer TIMMYDUCK's Avatar
    Feb 2003
    The 14th State Vermont
    Bar end removal
    Ride your bike to my house and I will do the install for you .
    TIMMYDUCK
    Jul 2004
    Vermont
    Bar end removal
    Thanks homie, I appreciate it If I get stuck, I might take you up on that.....
    I'll probably go out and buy two new bar ends, since the rubber stopper on the one that was already installed was pretty violated, and I dont like how it seated.
    I'm thinking I might hit it with some penetrating oil, and drill out some of the rubber.
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Bar end removal
    If thats not weld try tapping it IN first a little by hitting the end of the cap screw
    If its a taper like deal this should break it free
    Glen Beck is John the Baptist
    Waterbury, VT
    Bar end removal
    The outer sleeve looks to be a press fit into the bar end. Soak it with penetrating oil, find a socket or short piece of tubing with good square cuts on the end that has an ID a little bigger than the ID of the bar, a fender washer, and a bolt long enough to reach through the washer, socket, and engage a good number of threads into the bar end. You are putting together a crude puller. As you tighten the bolt, it should draw the old bushing out. If this doesn't work, it will need to come out in pieces.
    Drill as many holes in the rubber as you can, rip the center out, and then use a hacksaw blade to cut slots into the outer sleeve.
    Good Luck...
    SSearchVT
    Oct 2001
    Massachusetts
    Bar end removal
    F-you Grandpa!!!!!!
    - Mike
    CBR 1000 RR
    CBR 600 F4
    Jul 2004
    Vermont
    Bar end removal
    I ended up drilling aout 8 holes all the way around the steel inset the bolt threaded into, and ripping the whole mess out. It was a pain in the ass.
    May 2002
    Meriden CT
    heat realy wooks no better then fire 2 get stuck shit
    wtf cookie they dont listen
    www.bostonmoto.com
    Forum Rules
    Bar end removal
    Personally i would have bought one new OE yamaha bar end insert and 2 new OE yamaha bar ends and done away with those squidlookdonothingposerbarends
    Ense petit placidam sandman's Avatar
    sema
    Bar end removal
    or make your own custom stainless ones
    jim
    "Molon labe"
    Jul 2004
    Vermont
    Bar end removal
    They may indeed be squidly, but they do a wonderful job of dampning some of the vibration - which I found out after riding the bike with one stock one, and one "squidly" one.
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    This took HOW LONG?
    Dude PIPE wrench or these easy out gizmos:
    Remember if its an insane torque and its not budging........................maybe left hand threads?
    -Suf Daddy
    Suf Daddy.
    Nov 2003
    Torque those Fockers..............
    -Suf Daddy
    Suf Daddy.
    Pepperell, MA
    Bar end removal
    Holy fucking leverage bar!!
    Bar end removal
    oh man, those nut/bolt extractors are the fucking TITS, aren't they?
    Waterbury, VT
    Bar end removal
    So I'm not the only one who brings tools back to Sears in pieces. I usually just shrug my shoulders and smile when they ask me how it happened...
    SSearchVT
    Mar 2004
    woonsocket ri
    Re: Torque those Fockers..............
    Originally posted by Suf Daddy
    -Suf Daddy
    ok i have to ask. What bolt need that much torque to undo? Perhaps some heat would be in order.
    May 2002
    Meriden CT
    lol control arm ball joint
    www.bostonmoto.com
    Forum Rules
    Nov 2003
    Its sort of a staged photo.
    They are round head Hex / Allen socket 8mm caliper carrier bolts needed to be removed to get the rotor out.
    The center allen part: rusted and stripped, so the bolt extractors were used and the bar is an extension to make undoing a simple thing.
    -Suf Daddy
    Suf Daddy.
  1. 05 636 Air Box Removal
    By yellosuzku in forum Bike Maintenance
    Last Post: 03-11-09, 05:35 PM
  2. Clue Removal!?
    By JunoAF in forum General Bike Related
    Last Post: 08-14-08, 10:03 PM
  3. Bearing Removal.
    By oreo_n2 in forum Bike Maintenance
    Last Post: 10-03-02, 09:29 PM
