Results 1 to 7 of 7
New used bike in the garage - winter project
    Aug 2009
    Added a 2004 Honda ST1300 w 17k on the clock
    Paging Gino to the ST phone.
    Plan is to get everything ship shape and use it for a summer week or two trip, maybe even a second cross country trip.
    I’ve owned this motorcycle (not this exact one) before but what would the collective wisdom suggest I make sure to go over beyond oil change, shaft oil change and tires
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: New used bike in the garage - winter project
    Date codes on the tires. Based on that mileage the bike is on maybe its second set of tires.
    Change the brake and clutch fluid.
    Check all of the brake and clutch lines. They are all rubber and all 16 years old.
    Check the brake pads.
    Aug 2009
    Tires are toast, new rubber is a must, especially since this is a long distance runner.
    Pads look good, but I’ll check and clean the calipers when the wheels are off, something where that beloved single sided swing arm is a blessing.
    Don’t have the tools to do fluid changes, will likely put that on the Bettencourt list.
    What about forks if the seals look good?
    Mar 2012
    Chichester, NH
    Ohh, fork oil is probably garbage. At least plan on swapping out the fork oil.
    Rear shock might be garbage. It should be at least evaluated. At a minimum the bumper on the shock is probably dry rotted (assuming there's a bumper).
    ETA:
    lol. I was replying when you replied...
    If your are changing the fork oil, fork seals are pretty cheap, generally (I haven't looked at prices for this particular bike, but generally they are cheap).
    For brake fluid changes, look into speed bleeders. They make it a simple job for anyone to do.
    rides bikes
    Nov 2014
    Get some HARD tires for it. My buddy had one and we did some long trips together. The weight of that bike when loaded up absolutely shredded rear tires for him.
    He also ran into some electrical issues, which may have been unique to his bike. A PO added a bunch of lights, volt meter, etc.
    Aug 2009
    Will go Michelin Road 5. https://www.revzilla.com/motorcycle/...t-road-5-tires
    This is all stock, so I’ll make sure the regulator is good.
    Metzler Z8 interact is worth a look for heavier bikes New used bike in the garage - winter project
    CCS/LRRS #83
  1. New Track Bike Winter Project
    By dougie in forum General Track Day Talk
    Last Post: 11-13-13, 12:38 PM
  2. My winter project
    By xxdcmast in forum Pit Area
    Last Post: 02-04-08, 12:29 PM
  3. Winter Project
    By MsHap in forum General Bike Related
    Last Post: 01-30-05, 09:04 AM
