Page 1 of 3 123 LastLast
Results 1 to 25 of 61
need a bolt extracted
    picked up a frame over the weekend. has a crankcase adjust bolt that goes through the back motor mount stuck in the frame. was able to remove one of them with an impact gun. no thread stripping, just most likely seized on there from heat and time sitting. the outbound side where you'd use a 19mm socket after removing the castle nut was already stripped from the shop that disassembled the bike. the inside of the bolt stripped on me last night with a 12mm hex bit. i've used heat. i took a grinder off to the edge and tried with a big ass pipe wrench. it's really stuck in there. guessing the outbound side might have been peened a bit and now is stuck.
    so where can i bring this to get extracted? i'm in the south shore.
    here are some pics of the bolt, so you get an idea
    need a bolt extracted-41921-35f00-000_a-jpg need a bolt extracted-capture-png
    need a bolt extracted-download-jpg need a bolt extracted-l640-jpg
    Re: need a bolt extracted
    Drill it to round it out? Then tap it with a reverse thread and use another bolt to get it out?
    i'm not doing that, and this is a fairly big bolt
    That should make it that much easier to do it the way I mentioned.
    if it stripped from a 12mm hex socket using a 3 foot breaker bar and a massive pipe wrench with heat, it's really stuck in there. dont think a drill would extract it out.
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    Maybe try heating the local area around the bolt and then spraying some duster in a can at it upside down to shock it?
    You could take it to a machine shop, I'm sure they'd come up with something.
    The shop would most likely just drill it out almost to the thread and then just peel it out.
    LRRS 878 Clapped out Gixxah
    ok, let me repeat from post 1....
    where can i go in the south shore to extract this bolt?
    i do not want to try and remove it anymore
    Just trying to save you a trip and some money. Either way, it doesn't sound like you're understanding me correctly.
    Good luck, cupcake...
    Arlington MA 02474
    If it wuz me, I'd try Harry's Machined Parts in Northborough MA.
    Not So. Shore, but ...
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    How do you think a machine shop will do it?
    It's not magic.
    I don't have any personal experience with them, but maybe try these guys? https://camcoracing.com/home/services/
    TWINS! xrocket21's Avatar
    Central Maine
    Coughlan machine in Norwood off route 2
    Drool over the big block blown boat motors while you're there.
    Tahoe City
    Did you try to get a couple of guys to lift it?
    bi-metallic/galvanic corrosion from dissimilar metals
    probably have to drill it out and heli-coil it
    Central Maine
    I took my aluminum brembo brake calipers to coughlan because when I backed the steel bolts out the aluminum threads came with them. They had been THOROUGHLY heat cycled too
    dropped it off to a local guy.
    i know i could drill it out, but i dont trust my skillset on doing that without messing up the frame threads. that's something i'd rather pay a specialist to do
    I would count on the frame threads already being FUBAR, heli-coils are pretty foolproof to install
    maybe. i was able to extract one of those thrusters and the frame threads were fine.
    i'm ok with doing helicoils. i did one on my radiator mount the other day. this would be a large helicoil though. like M21 if they even make them that large. just not something i was comfortable doing.
    I've done em for spark plugs, I would also send out something I am not comfortable doing. the other option is an insert, I had a machine shop do that for me once
    For those interested, the guy fixing Jim’s frame is my guy in Raynham, MA. He’s a retired machinist who has a small machine shop in his barn, he can also weld anything. He’s the “no job too small” kind of dude and is very reasonably priced. Located near the I495/Rt 138 interchange, I’ll be happy to put you in touch.
    Does he do frames with rim locks?
    5 Not allowed! Not allowed!
    Oct 2020
    Chelmsford, MA
    Sometimes you gotta go the other way - cold may get it loose rather than heat:
    https://www.youtube.com/watch?v=rljUld-ptvI&t=23s
    I thought that was your urologist?
    Oct 2020
    Chelmsford, MA
    Same idea, but with penetrant. I've have used it before and it does work. YMMV.
    https://www.crcindustries.com/produc...-oz-05002.html
    Dec 2009
    Late to the conversation but I would have suggested having someone tig weld a decent sized hex head bolt into it. The extreme heat from the welding process is far greater than what a torch would give while also being localized heat. It tends to open the gap between the the threads of the existing bolt and the frame section. A few seconds to let the weld set and then apply torque to the bolt head. It's what most of us have to do with those POS brake caliper bolts after somebody rounds off the hex head.
  1. Dropped bolt
    By 02redhawk in forum Bike Maintenance
    Last Post: 07-31-18, 12:56 PM
  2. Which bolt is it ?
    By danny86 in forum General Bike Related
    Last Post: 09-02-12, 07:10 PM
  3. WTB: Banjo Bolt
    By jcbell1007 in forum Wanted
    Last Post: 04-12-11, 12:21 AM
  4. How do you get out a snapped bolt ?
    By danny86 in forum Bike Maintenance
    Last Post: 06-05-10, 10:40 PM
  5. New Bolt On for Jim
    By csmutty in forum General Bike Related
    Last Post: 01-08-10, 06:39 PM
