Results 26 to 50 of 61
need a bolt extracted
    Lifer golden chicken's Avatar
    Attleboro, MA
    Re: need a bolt extracted
    Also late to the party with a suggestion that probably wouldn't have helped given just how hard you were probably cranking with the cheater bar, but if ever in doubt of rounding out a hex bolt, apply a little daub of valve lapping compound to the bit to give it more bite.
    For steel bolts in aluminum, sometimes I give a little blip of an impact gun in the forward direction first, just to crack it free.
    Nov 2008
    Framingham, MA
    ok, let me repeat from post 1....
    where can i go in the south shore to extract this bolt?
    i do not want to try and remove it anymore
    PK at GMD...you know the drill
    already got the frame back. bolt was extracted. thanks for the recommendation Duncan
    Attleboro, MA
    Any idea what method was used?
    yes. drop off and pick up. LOL
    7 Not allowed! Not allowed!
    he drilled two small holes down the sides to weaken it. i forget what else he said he did to make it break. said it was very stuck on there. the frame threads were undamaged. the bolt could loosely thread back in too.
    bumping this because now i need threads repaired.
    since that bolt was extracted, about half the threads got torn up.
    measured the thruster and it was about 21.5mm, so i'm guessing i need an M22 kit.
    looks like Helicoil doesnt make such a kit. looked around and saw some others but were $200-$500 for a kit to repair a single thread.
    i'm hoping someone might know of someone that can or has the tools to get this done. i'm at a loss right now.
    already installed new races as i was getting the frame ready to swap over on my bike.
    PK?
    Dublin, NH
    If you have the appropriate size tap, run it through a few times. I've gotten lucky on a few frame threads on my KTM where simply running a tap through took care of the threads.
    2023 KTM 890 Adventure R
    my kit doesnt go that high. the M22 taps i've seen online are $100 - $200.
    have a machine shop make you a threaded slug, that is drilled & tapped at the center for your stock fastener, then drill/enlarge & tap to the size of the slug. use red locktite
    or find a larger diameter fastener that works, and enlarge and tap to that size (what I did for one of the seat bolts on my SV650)
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    If the threads just need to be repaired (not tapped), you can make a "thread chaser" out of a bolt. Just dremel a decent sized groove in the side of the bolt so that the waste has somewhere to go, and thread it in carefully. Kind of like a poor man's tap.
    This will straighten and clean up the threads nicely.
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Dublin, NH
    You can get one for like $20 on Amazon. Yeah they may not be fantastic quality, but for a one time use you don't necessarily need quality.
    Half the threads are gone and I need to insert new threads
    Oct 2020
    Chelmsford, MA
    If you don't mind switchin bolts and going to 'Merica units I can lend you a tap that will do the job
    need a bolt extracted-pxl-20210708-144852005-jpg
    Oct 2020
    Chelmsford, MA
    it's for a specific bolt that centers the motor. cant switch to SAE unfortunately.
    i'd still need the tool that inserts the threads into the frame.
    Dublin, NH
    Prepare yourself before you click this link:
    https://www.threadtoolsupply.com/M22...epair-kit.html
    https://www.govets.com/index.php/e-z...MaAlz7EALw_wcB
    Obviously, verify thread size and pitch before ordering.
    https://www.amazon.com/PowerCoil-352.../dp/B008V13QHO and order a drill bit separate, etc.
    Oct 2020
    Chelmsford, MA
    Powercoil. Measure your threads and job thrice to make sure you order the right one.
    https://smile.amazon.com/dp/B008V13QHO
    is that brand any good? i was looking at them earlier on amazon
    it does look like i need an M22 x 1.5
  22. #47
    Oct 2020
    Chelmsford, MA
    Yep, good hard steel. You can resell your kit on ebay (-1 coil) if you want to recoup some of the costs.
    only thing i would need is a big ass drill bit before tapping the threads for the new insert.
    shipping will take a while, which cuts my frame swap project quite some time.
    red loctite on the new threads and good to go?
  24. #49
    Oct 2020
    Chelmsford, MA
    if you expect threads to wiggle around you want thread locking..now you're better off making your own kit. it comes out to about the same cost but of course you gotta call to order the special thread locking inserts
    https://crossroaddistributorsource.c...898&catId=1545
    https://smile.amazon.com/20-5mm-Redu.../dp/B07TXSBMP5
    https://smile.amazon.com/M22-Metric-.../dp/B00860BKWS
    https://smile.amazon.com/PowerCoil-3.../dp/B00MV1WGE4
    Looks like I need thr thread insert to be 15mm in length, and that kit has 33mm threads
  1. Dropped bolt
    By 02redhawk in forum Bike Maintenance
    Last Post: 07-31-18, 12:56 PM
  2. Which bolt is it ?
    By danny86 in forum General Bike Related
    Last Post: 09-02-12, 07:10 PM
  3. WTB: Banjo Bolt
    By jcbell1007 in forum Wanted
    Last Post: 04-12-11, 12:21 AM
  4. How do you get out a snapped bolt ?
    By danny86 in forum Bike Maintenance
    Last Post: 06-05-10, 10:40 PM
  5. New Bolt On for Jim
    By csmutty in forum General Bike Related
    Last Post: 01-08-10, 06:39 PM
