Results 1 to 9 of 9
Jetski Mechanic, Needed
    Posting Freak
    Oct 2004
    Anyone know or can recommend a good one....? 2002 seadoo needs engine replaced.
    Thanks
    Dublin, NH
    Re: Jetski Mechanic, Needed
    2-stroke jetski engines are extremely easy to replace yourself. A few bolts that hold the engine bedplate to the mounts, a few exhaust bolts and a few hoses and wires is all that holds the engine in the ski.
    If you wanna save yourself a few hundred $$, head on over to www.pwctoday.com and read up on everything you'll ever need to fix your own jetski.
    2023 KTM 890 Adventure R
    Lancaster
    sheppo maybe??
    Junior Member BulldogR1's Avatar
    Dec 2010
    Chelmsford, Ma
    I work at Billerica Motorsports and must say that we have an amazing service department. We're also a diamond dealer so we can get the parts much faster than most dealers.
    RC51FMT RC51FMT's Avatar
    WHITINSVILLE/MA
    If you have the engine , I can replace it . whats wrong with the motor in it know? whats it doing?
    Cabin Fever kb1's Avatar
    Dec 2008
    Down South
    Stoneman can't take care of this?
    Posting Freak
    Oct 2004
    2001 GTI I think the engine is seized...crank barley turns when you try to turn it by hand with the plugs out and I think the steering cable needs to be replaced too.( the handle bar does not turn either).I donr know anything about these machines. SBT has engines for cheap but I am not good at water crafts.
    WHITINSVILLE/MA
    You shore its not the pump binding up . Im big into standups mostly. But i buy, fix , and part out skis. Ive rebuilt a few yamaha, and kawi engines . I havent worked on a sea doo yet. all 2 stroke jetski engines are close to the same. If you want i can check the pump for you . If the pumps not sezied we can pull the engine , take the cylinders off and check whats going on with it.
    Walpole
    Quote Originally Posted by kb1 View Post
    2018 Harley Road Glide
    2000 Ducati 900ss
    2026 Suzuki DR-Z4s+
  1. Triumph Mechanic Needed/NH
    By tonup in forum Bike Maintenance
    Last Post: 04-10-17, 11:17 AM
  2. qualified mechanic needed
    By landricscustoms in forum Off-Topic
    Last Post: 05-05-10, 08:15 PM
  3. Boat Mechanic needed
    By mycirus in forum Off-Topic
    Last Post: 07-01-09, 06:58 AM
  4. Replies: 4
    Last Post: 12-02-08, 03:28 PM
