Results 1 to 25 of 25
Getting rid of rust build up in gas tank
    Jun 2012
    Westborough
    Getting rid of rust build up in gas tank.
    Online I have seen people using Apple Cider Vinegar and letting it sit in the tank for a couple days then once the rust is loose just running it through water.
    How have you treated this?
    Re: Getting rid of rust build up in gas tank
    i'm in the process of doing it now.
    2 gallons of EvapoRust. leave it on a section/side for 2 days, then rotate.
    rides bikes
    Nov 2014
    50/50 evaporust and water for 3 days and flush is my current go-to.
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    I did the vinegar process on a Marauder tank a few years ago. Removed a bunch of rust, though it created a ton of pin hole leaks. lol. Tried lining it, failed. Ordered new tank on ebay...
    +1 for evaporust. It’s paint safe and reusable, which is nice.
    My uncle recently went to the internet for rust removal advice for his ‘74 Z1 tank. He read something about vinegar and baking soda.. but missed the part where it’s two separate steps. He sealed it up tight and left it to work it’s magic.
    He’s buying a replacement now. I laughed a lot.
    Quote Originally Posted by petro View Post
    Did it inflate?
    Jun 2012
    Westborough
    Doing the evapoRust. thanks guys
    Oxalic acid
    Did it inflate?
    Right up until a seam blew out!
    Did it inflate?
    cheap trick to expand a tank for endurance racing
    cheap trick to expand a tank for endurance racing Getting rid of rust build up in gas tank
    I made an endurance tank on an extra by accident once. Popping out dents with air pressure, couldn't see that the bottom was ballooning until it was too late. Hahaa
    Member DirtDawg21892's Avatar
    May 2019
    Nashua NH
    Electrolysis worked really well for me. I basically flipped the tank on its back, filled it up with water and baking soda, and put a graphite rod in through the petcock hole. Just make sure the rod is insulated and not touching metal on the end or on the edge where it enters the tank, otherwise you've got a short. then you just hook a battery charger or other current source up to the tank and the rod. rust flows from negative to positive, so the rod is the anode.
    It worked way better than I expected. It's pretty basic chemistry and I was just messing around, but that bike is still on the road today.
    Lifer ZX-12R's Avatar
    Candia, NH
    Project Farm videos on rust removal.
    This one is a bunch of liquid products including Evapo-Rust:
    And this one is electrolysis vs. Evapo-Rust:
    but would you trust those other chemicals with a gas tank?
    Candia, NH
    For me it would depend on the general health of the tank. The acidic removers work the fastest but in many cases can erode the underlying material. If the rust isn't bad and the overall structural integrity of the tank isn't in question, I wouldn't have any problem with those types of removers. They aren't meant to be left in unsupervised.
    The selective chelating rust removers like Evapo-Rust are inherently safer as they don't attack the underlying metal. They don't work as fast but you can generally leave them unsupervised for a long period of time to do their work.
    rides bikes
    Nov 2014
    If your tank is so bad that properly cleaning it compromises its integrity, you might want to hop on eBay for a new tank. If you just lightly clean it and then coat over the rust/rot, it'll lift the liner and/or start rusting outwards.
    Massachusetts' Noth Shoah
    I also had very good results with electrolysis.
    Go fast. Have fun. Repeat.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    How about taking about a cup of small nuts and washers and just a little gas or maybe baking soda with water and swirling them around in the tank a while and then rinsing with clean gas?
    have you ever tried retrieving anything out of a gas tank ? the only abrasive you want to use is a length of light chain
    That's actually a really good idea. Bicycle chain would be perfect.
    Oct 2020
    Chelmsford, MA
    ultrasonic, but the steps are inside-out: you dunk a cheapo chinese ultrasonic vibrator into a tank filled with greenclean or whatever liquid you like to remove the rust. but cleaning just buys you time. a used tank is 100% worth the cry if you can find the matching color.
    https://smile.amazon.com/dp/B08DNG7QM6
    holland ma.
    I have an old harley tank thats all rusty and has a liner falling out of it. Gonna toss a chain in and see what it can do. I may step up to some screws if that liner is stubborn. Vinegar will finish off the rust if any is left.
    Any good liner kits out there now? I did a cadwell coating on my last bike but its like glass and is cracking now.
    Or tie them to a length of wire sorta like a necklace...
    Oct 2020
    Chelmsford, MA
    the way I used to clean tanks was a handful of ball bearings and a 20 minute shake. a chain won't get into the nooks and crannies of the tank. pull them out with a pickup magnet tool. if you are smart enough to count how many you dump in you know if one is stuck. doing that with evaporust and sitting it overnight will clean it like taco Tuesday
    Lifer LuvDog's Avatar
    Ashland, MA
    I used a cheap soda blaster setup from HF
    2003 ZX7R
    1995 916
  1. Gas tank rust, fix or not...
    By Tekime in forum Bike Maintenance
    Last Post: 06-29-17, 02:01 PM
  2. Removing rust from inside a gas tank
    By Petorius in forum Bike Maintenance
    Last Post: 06-14-15, 06:18 AM
  3. Rust in tank
    By stevecbr900rr in forum General Bike Related
    Last Post: 10-19-08, 07:26 PM
  4. removing rust from a gas tank.
    By taxonomy in forum Bike Maintenance
    Last Post: 08-20-08, 06:55 PM
