Results 1 to 25 of 35
Strange tire grip fact.
    Member taxonomy's Avatar
    Northampton, MA
    I am reading Tony Foale's Motorcycle Handling and Chassis Design. It's nearly an impossible read for the novice, which I surely am.
    Anyhow, I thought I would pass this on.
    Tires exhibit maximum grip when they are sliding about 10%. This is to say that a tire will deliver more forward thrust on an accelerating bike where there is about 10% slippage. That is the tire is moving about 10% faster than the contact patch.
    This also holds true for cornering. So, the tire will deliver some amount more camber thrust when it's not hooked up completely. Weird, but true, if I am reading it right. Smarter folks feel free to chime in.
    Me: "Normal people wouldn't do this."
    Peter: "First you have to operationalize with normal is."
    Newbie
    barre
    Re: Strange tire grip fact.
    This tire grip fact sounds likes you are 10% closer to testing your frame sliders!
    I93/495
    same thing works under braking as well
    10% slip under acceleration and braking. 6-8 degree slip angle when cornering.
    Easier to achieve with cars than with bikes because of the obvious consequences on a bike. There's probably only a handful of people on the planet who can do it regularly on a superbike.
    2012 Tiger 800 XC
    Northampton, MA
    I would imagine anyone off the front in MotoGP is working this limit.
    Crazy.
    A
    thinks he wants a FZ6 intergalactic's Avatar
    Southern NH
    Quote Originally Posted by taxonomy View Post
    10% is a wicked generalization, and things change depending on the tire, but yeah. Slip=grip. And depending on what the slip to grip curve looks like, you can get lots or very little notice that you are approaching or past the peak.
    Northampton, MA
    Hence "about". I was just surprised a tire delivers more thrust in slip mode than grip mode.
    One thing that I think a lot of beginning riders don't get is slide does not equal crash.
    I think what most people don't realize is that slip does not equal a detectable slide. I have watched bikes from EX500s all the way up to liter bikes laying darkies out of the turns at Loudon. Most times I mention it to someone they are like, Really? I didn't notice.
    The tire is in slip stage well before you can perceive it. Once you feel a slide, you might be surpassing that optimum thrust zone.
    who knows
    Northampton, MA
    There it is, people smarter than me. Hence, "slip angle".
    I has suspected something like that. Slide is beyond slip, and way off the back of the grip bell curve.
    Lifer Stromper's Avatar
    Eastern Ct
    In real drag racing they say that number is closer to 33% faster
    I thought that would be due to "adhesion" rather then rubber extruding into surface irregularities
    Northampton, MA
    That varies considerably from the "meshing gears" idea that I had before I started reading this. My idea was basically that highest grip is static and that it starts falling off quickly when it exceeds that.
    Turns out it isn't so.
    Senior Member spydah's Avatar
    Fitchburg, MA
    It makes sense if you consider that tires are more sticky when they are warm, and when a tire slips there is more friction since it is moving faster than the surface it touches. More friction = more heat = stickier tire.
    LRRS #831 Novice
    2007 Ducati 1098 - Street (okay, sometimes track)
    2002 Suzuki sv650 - Pure track!
    2007 Suzuki sv650 - Next seasons track bike
    http://www.myspace.com/spydah77
    I93/495
    Depends on the tire. R comps are less forgiving then street rubber
    2012 Tiger 800 XC
    Raymond NH
    When I think about how a bike is turned (pushing the handlebars away from where you want to turn) I'd guess that turning always involves some sliding, at least on the front tire. I have a 1:25 scale model of my 9R here at my desk and I cannot get it to turn (with the front wheel straight or) without sliding.
    Wirelessly posted (Instinct: TELECA-/2.0 (BREW 3.1.5; U; EN-US; SAMSUNG; SPH-M800; Teleca/Q05A/INT) MMP/2.0 Profile/MIDP-2.1 Configuration/CLDC-1.1)
    this is why you countersteer...to slide the rear.
    Raymond NH
    I respectfully disagree. I think the front slides and the bike corners because it's following the path the side of the rear tire wants to take for a given angle of lean. I could be way off base though.
    Northampton, MA
    I think the "slide the rear" thing was a joke.
    There is some element of scrub when steering, but I don't know if it's enough to really think of it as sliding on the order of full percentage points.
    I'm also pretty sure that a model is going to be a pretty poor approximation given the complexity that's actually occurring.
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    I too, was surprised to hear this when I read Foale's book.
    It is as Paul says, that slip angle that produces the most grip is imperceptible to most mortals. If you saw the graph describing this effect, you'd see that the time when grip is optimal is of a pretty short duration. Once you exceed this peak, then you suddenly lose a huge amount of grip.
    Eastern Ct
    You steer the tires out from under the center of gravity and that levers the bike into a lean
    tires don't slide so much as the distort in a continuous wave
    Sep 2001
    Western MA
    True, but that's a different aspect of cornering. Slip angle deals with what happens after the bike is leaned and affects how much grip is present.
    The science of grip was explained to me with a boat prop as the example.
    The prop acheives maximum forward thrust when there is slight cavitation occuring as this is when it is displacing the most amount of water. Beyond a certain point, when you have more cavitiation there is less forward thrust. The other end of the spectrum seems to be obvious, that being, if there isn't any cavitation then you are not displacing the maximum amount of water the prop can handle.
    Make sense? Does to me.
    Quote Originally Posted by stoinkythepig
    Maybe slide should be in quotes.
    when a motorcycle corners at speed that requires you to countersteer the rear tire takes a wider line through the turn than the front,(unlike a car where the rear takes a tighter line than the front) i call this "sliding the rear". its way more prominant on a dirtbike than a streetbike.
    Eastern Ct
    Thinking causes wrinkles
    best post ever!
    Sep 2001
    Western MA
    No wonder the guy in the mirror looks like Yoda.
  1. Fun Fact: GoPro's bounce
    Last Post: 08-18-12, 09:51 PM
  2. Interesting Fact
    By Zero in forum General Bike Related
    Last Post: 07-06-06, 03:09 PM
  3. Trackday...the events after the fact
    By Jaynnus in forum General Bike Related
    Last Post: 06-03-05, 11:22 PM
